3D horizontal axis wind turbine, OpenFOAM beginner |
July 16, 2015, 07:19 |
CFD
Hey all.
I want to do a small, relatively simple study of a horizontal-axis wind turbine. At least (like a lot of things), it seems simple in concept. I have not studied CFD before, but some of the concepts seem fairly intuitive. There're https://www.youtube.com/watch?v=MLdY-bWJBJM, https://www.youtube.com/watch?v=TkIT1jkD9PE, and https://www.youtube.com/watch?v=E77Kw-nXMtA on Youtube which was apparently done using OpenFOAM, but there are no hints on how to recreate their work. I've created a 3D FreeCAD model of the shroud with actuator disk model, but I have no idea (yet) how to define the wind flow, boundaries, rotation, etc. As this is a side project I might take a lot of time learning how to operate OpenFOAM from scratch - and I'm not exactly a programming or command-line wizard, although I can more or less manage. So if someone can give me guidelines that would be really great. I'd just like to set up wind flow from one direction, and plop the model in the middle and see what happens, and then try again with the model rotating. I'm sure it's not as simple as that (I'm reading through the documentation in my free time), but any help is appreciated to speed things up! Thanks! |
2D vertical axis wind turbine, OpenFOAM beginner | Boloar | OpenFOAM | 30 | January 17, 2022 04:14 |
CFD of Vertical Axis Wind Turbine | shashankmechguy | FLUENT | 0 | June 1, 2014 21:47 |
2D Modelling of Horizontal Axis Wind Turbine | Richeom | Main CFD Forum | 1 | April 7, 2014 17:43 |
Request: horizontal axis wind turbine | fadel_n | FLUENT | 3 | October 20, 2013 14:43 |
Vertical axis wind turbine in NUMECA | ArslanOZCAN | Fidelity CFD | 2 | July 21, 2011 05:04 |
