July 21, 2015, 17:16 |
DAKOTA/Openfoam
samira
Rep Power: 11 |
Dear everyone,
I am working on airfoil shape optimization with openfoam and Dakota.. The a irfoil shapes are parameterized using Bezier curves,12 control points are used for parameterization,For an airfoil curve, two points are fixed since they represent the leading and trailing edge of the airfoil. The intermediate points are a llowed to move within the specified boundaries. A maximum thickness constraint of 19% - 22% of chord is imposed on the airfoil.. how I define control points and The constraints in DAKOTA for generate different airfoil? Any comments and suggestions are welcomed Best regards Samira |
July 27, 2015, 09:45 |
samira
Rep Power: 11 |
waiting for a reply
July 28, 2015, 06:11 |
Niels Nielsen
Rep Power: 27 |
Using Google for 1s,
First result. http://www.dicat.unige.it/guerrero/dakotaof.html Second result http://www.tfd.chalmers.se/~hani/kur...nsource_AJ.pdf Nobody are going to give you a ready to run case, you need to do the leg work yourself.
Linnemann PS. I do not do personal support, so please post in the forums. |
