How to use the functionobjects add?
Old   March 26, 2018, 01:10
Default How to use the functionobjects add?
Bingchuan
bingchuan is on a distinguished road
Dear foamer,
The manual says that the functionobjects add can be used to " Add a list of fields."
At the same time, the code gives an example as
Ttot {
 type            add;
 libs            ("libfieldFunctionObjects.so");
 fields          (T Tdelta);
 result          Ttot;
 executeControl  writeTime;
 writeControl    writeTime;
But, it is still confusing for me. Can anyone give me more details about when to use it and how to use it. It seems that no such an example in the tutorials.
Bests.
Bingchuan
bingchuan is offline   Reply With Quote
Old   March 26, 2018, 12:43
Hosein
einstein_zee is on a distinguished road
Originally Posted by bingchuan View Post
Dear foamer,
Ttot {
 type            add;
 fields          (T Tdelta);
 result          Ttot;
Bests.
Bingchuan
Hi there,
I think you forgot to read the next line which states "The operation can be applied to any volume or surface fields generating a volume or surface scalar field." I think this is quite clear about what this class does.
einstein_zee is offline   Reply With Quote
Old   March 27, 2018, 08:03
Bingchuan
Dear Hosein,
Thank you for your reply.
In fact, I have read "The operation can be applied to any volume or surface fields generating a volume or surface scalar field " before. Since I am new with OF, it is still confusing for me.
I was wondering:
1) Does it have the same efficacy with the VolVectorField or VolScalarField in the creatFields.H?
2) If I created a field by the functionobject add, say a field XX which is related to the temperature. I think the calculation expression of XX should defined in the code. Where should I define the calculation expression of XX ?
So, could you please give me more details, such as sharing an example? Many Thanks.
Bests,
Bingchuan
Old   March 27, 2018, 09:09
Hosein
Hey there,
I think you mixed up some things with each other. To see what function objects do in general you might refer to this page "https://cfd.direct/openfoam/user-guide/v3-function-objects/".
volVectorField and volScalarField are just variable types in OF. And this has nothing to do with the function objects.
Going back to our function object "add", this will add two or more scalar fields with each other. So this means you need to have a volScalarField (exp. temperature as it is stated in the example) defined either on a volume region or a surface one, to add them. The calculation that you referred, here is addition.
Old   March 28, 2018, 04:48
Bingchuan
Dear Hosein,
I got it
The add function object is just to create a new field which is a sum of a few existing variables. I got it mixed up with registering a new field.
Thanks.
Bests,
Bingchuan
Old   June 6, 2020, 14:03
Himanshu
Himanshu_Shrivastava is on a distinguished road
Dear Hosein,
I got it
Thanks.
Bests,
Bingchuan
Hii, Can you post an example for this add function...
Himanshu_Shrivastava is offline   Reply With Quote
Old   June 6, 2020, 16:36
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Hope this helps: https://www.openfoam.com/documentati...field-add.html
HPE is offline   Reply With Quote
Old   June 8, 2020, 12:41
Himanshu
Originally Posted by HPE View Post
Hello Herpes,
Thank you for the quick reply.
I have seen that page but as I am new to oF and currently in learning phase, I have some doubts and was not able to understand clearly from that page.
Hence, I asked for an example to understand better.
If you allow, Can I asked few question regarding function object. I swear those are easy doubts but not for me
Old   June 8, 2020, 16:24
HPE
HPE's Avatar
A minimal example might be, say you want to add two fields of the same size and dimensions, X and Y:
add1
    type            add;
    libs            (fieldFunctionObjects);
    fields          (X Y);
You need to put the above inside `system/controlDict` file under `functions` subdictionary. Just append the following to your `controlDict` file if there is no `functions` subdictionary exists:
functions
    add1
        type            add;
        fields          (X Y);
Old   June 9, 2020, 10:08
Himanshu
add1
    type            add;
    fields          (X Y);
functions
    add1
        type            add;
        fields          (X Y);
Hello Herpes,
Thank you for the example. I just read many post last night and many of doubts were solved.
Thanks!
add, functions
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 11:04
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[PyFoam] and paraview eelcovv OpenFOAM Community Contributions 28 May 30, 2016 09:23
[DesignModeler] add two area around Cylinder in ansys sajjadcheraghian ANSYS Meshing & Geometry 0 May 23, 2016 12:42
OpenFOAM v1.6 & OpenMPI & functionObjects bruce OpenFOAM Running, Solving & CFD 1 August 7, 2009 13:15
