I got sigFpe error after applying mapFields to a subdomain |
July 4, 2016, 20:30 |
SSSSS
Rep Power: 14 |
I have two domains. one is large domain and the other is a subdomain of the first one. I ran a simulation with the large domain with RAS. Using the RAS result, I want to map the solutions into the subdomain boundary. After ran mapFields in the subdomain case directory, with Paraview the boundary value looks good. However, OpenFOAM make sigFpe when I try to run a simulation with the subdomain with the mapped boundary value as follows: Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: no residual control data found. Calculations will employ 2 corrector loops Reading field p Reading field U Reading/calculating face flux field phi [23] #0 Foam::error:rintStack(Foam::Ostream&)[49] #0 Foam::error:rintStack(Foam::Ostream&) in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/lib/libOpenFOAM.so" [49] #1 Foam::sigFpe::sigHandler(int) in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/lib/libOpenFOAM.so" [23] #1 Foam::sigFpe::sigHandler(int) in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/lib/libOpenFOAM.so" [49] #2 ? in "/lib64/libc.so.6" [49] #3 Foam::surfaceInterpolation::makeWeights() const in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/lib/libOpenFOAM.so" [23] #2 ? in "/lib64/libc.so.6" [23] #3 Foam::surfaceInterpolation::makeWeights() const in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/lib/libfiniteVolume.so" [49] #4 Foam::surfaceInterpolation::weights() const in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/lib/libfiniteVolume.so" [23] #4 Foam::surfaceInterpolation::weights() const in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/lib/libfiniteVolume.so" [49] #5 ? in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/lib/libfiniteVolume.so" [23] #5 in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/bin/pimpleFoam" [49] #6 __libc_start_main in "/lib64/libc.so.6" [49] #7 ? in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/bin/pimpleFoam" [23] #6 __libc_start_main in "/lib64/libc.so.6" [23] #7 ?? in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/bin/pimpleFoam" [ddcc24:mpi_rank_49][error_sighandler] Caught error: Floating point exception (signal 8) in "/home/apps/openfoam/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64IccDPInt32Opt/bin/pimpleFoam" [ddcc09:mpi_rank_23][error_sighandler] Caught error: Floating point exception (signal 8) [ddcc24:mpispawn_3][readline] Unexpected End-Of-File on file descriptor 9. MPI process died? |
Personalization of mapFields and libsampling - Compilation issues | saimat | OpenFOAM Programming & Development | 3 | June 29, 2016 08:56 |
Strange random behaviour of mapFields | blaise | OpenFOAM Pre-Processing | 0 | November 3, 2014 09:37 |
two subdomain in fluid domain does not word (CFX) | maxwellandi | CFX | 4 | November 28, 2012 15:45 |
