bubbleInterTrackFoam and Mass transport
Old   July 12, 2011, 00:10
Default bubbleInterTrackFoam and Mass transport
Kelvin Loh
kel85uk is on a distinguished road
Hi all,
I am trying to model mass transfer across a bubble interface using bubbleInterTrackFoam, but when I added the scalar transport equation into the solver, it does not solve anything.
The following is an excerpt of the solver. Any help and suggestions on how to make this work? Thank you
Kelvin
#               include "continuityErrs.H"
                // Momentum corrector
                U -= fvc::grad(p)/AU;
                U.correctBoundaryConditions();
//#           include "solveBulkSurfactant.H"
#           include "species_transfer.H"
            interface.correctPoints();
#           include "freeSurfaceContinuityErrs.H"
#       include "updateMovingReferenceFrame.H"
#       include "volContinuity.H"
Info << "Solving the species field" << endl;
DT = fluidIndicator*( DTA - DTB ) + DTB;
solve
  fvm::ddt(C_O2)
  + fvm::div(phi - fvc::meshPhi(rho,U), C_O2)
  //+ fvm::div(phi, C_O2)
  == fvm::laplacian(DT, C_O2)
File Type: h species_transfer.H (860 Bytes, 11 views)
kel85uk is offline   Reply With Quote
Old   July 12, 2011, 03:47
Bernhard
Bernhard is on a distinguished road
I have the impression that you are now solving the convection-diffusion equation in two seperate domains (you can easily check that I think with a simple case).
For the mass transfer across the interface, you should somehow communicate between the patches freeSurface(Shadow).
Bernhard is offline   Reply With Quote
Old   December 24, 2012, 07:25
Default bubbleInterTrackFoam + Mass Transport
Hanniel Freitas
hfsf is on a distinguished road
Kel85uk,
I would like to know if you could share your bubbleInterTrackFam + Mass transport implementation with me. I'm working with the same topíc, a falling drop with the conjugated solute transport to the exterior, but I'm having trouble even setting the case. Any help is appreciated .
Best regards,
Hanniel Freitas
hfsf is offline   Reply With Quote
Old   May 11, 2016, 07:48
Eli1993's Avatar
Arahata
Eli1993 is on a distinguished road
Hello everyone
I am using bubbleInterTrackFoam to simulate a bubble rising in a liquid column.I got some error like bellow
Create time
Create dynamic mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: laplace
Selecting motion diffusivity: uniform
Reading field p
Reading field U
Found free surface patch. ID: 1
Found free surface shadow patch. ID: 0
--> FOAM FATAL ERROR:
Error in B-to-A face patchToPatchInterpolation.
From function freeSurface::makeInterpolators()
in file makeFreeSurfaceData.C at line 105.
FOAM aborting
Can anyone pls tell me what to do
Eli1993 is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
HELP PLS: Simplefoam manipulated to add diffusive mass transport...but solver stops!! 1gn0rant OpenFOAM Running, Solving & CFD 1 August 13, 2010 11:02
PROBLEM: Scalar mass fraction Lorenzo Siemens 1 July 14, 2008 03:50
Mass transport within a jet Lam Main CFD Forum 0 August 23, 2007 15:17
