-   OpenFOAM (https://www.cfd-online.com/Forums/openfoam/)
-   -   PotentialFoam Error (https://www.cfd-online.com/Forums/openfoam/172307-potentialfoam-error.html)
ocni May 28, 2016 05:14
PotentialFoam Error
Hey guys,
I'm trying to simulate a flow through some ducts in Sim-Flow. I'm new to this software and I keep getting this error: "Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow."
My boundary conditions should be right and I use Potential Flow Initialization.
Does anyone have an idea to fix this?
http://imgur.com/usDHKU9
Thanks!
PS. I tried to insert a picture of the error message. It doesn't seem to work. So here is a link http://imgur.com/usDHKU9
elmo555 May 31, 2016 08:42
Hey Christian,
you said that your boundary conditions "should be right". How exactly did you set the BCs? Do you have an outlet?
ocni May 31, 2016 10:49
Yes, I have an outlet defined as an outflow.
elmo555 May 31, 2016 10:53
In both the pressure and velocity field?
