Brownian force to icouncoupledkinematicParcelFoam
Old   June 1, 2016, 12:00
Default Brownian force to icouncoupledkinematicParcelFoam
Evangelos
Danath is on a distinguished road
Hello !
I want to add the Brownian force to icouncoupledkinematic... due to the nanocale of particles. I add BrowniaMotion to particles forces at constant/kinematicCloudproperties but the force is not valid.
Then i add Brownianforce.H to lagrangian/intermediate/lninclude/makeParcelForces.H. But there are errors in the process of compilation.
I solve many of them except one.
lnInclude/BrownianMotionForce.C:179:28: error: ‘const parcelType’ has no member named ‘Tc’
How can make icouncoupled... to read both makeparcelforces.H and makeThermoparcelforces.H
Can somebody help ?
Thanks in advance.
Danath is offline   Reply With Quote
Old   June 3, 2016, 10:47
Evangelos
The problem solved but it seems that the model of brownian force does not work properly .
The velocity of the spheres is very high.
Any help will be greatly appreciated.
Originally Posted by Danath View Post
Hello !
Can somebody help ?
Thanks in advance.
Old   June 7, 2016, 13:40
Evangelos
Solved !
The dt that used by the code is not the timestep and the boltzmann constant is in eVK^-1 but we must set it in J/K
Old   July 11, 2016, 06:21
Karelke Yu
cfdopenfoam is on a distinguished road
Hi, Evangelos.
I also want to add some type of force to the icoUncoupledKinematicParcelFoam.
Is that possible for you to share your code here so that more foamers could benefit when facing the same problem?
thank you in advance!
Best,
Karekle
cfdopenfoam is offline   Reply With Quote
Old   April 11, 2018, 22:00
Ping Chang
chpjz0391 is on a distinguished road
Hi all,
Do you solve this problem? can you please share your code? I met the same problem. How you add the brownian into icouncoupledkinematicFoam or DPMFoam
chpjz0391 is offline   Reply With Quote
Trackbacks are On
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 12:12
Can Brownian force be used in turbulent flow? Chen Fangzhi FLUENT 3 August 3, 2013 14:21
Force can not converge colopolo CFX 13 October 4, 2011 23:03
time scale in brownian force Mehdi Asghari FLUENT 0 May 17, 2008 02:02
time scale in brownian force & submicron particles Mehdi Asghari FLUENT 0 May 16, 2008 13:42
