OpenFOAM2.0.0
Old   August 4, 2011, 12:03
Default OpenFOAM2.0.0
huxiaoxia
huxiaoxia is on a distinguished road
Hello, all:
I try to run the example of rivuletPanel with OpenFOAM 2.0.0. But there are some problems. The steps that I have done are:
1. run the blockMesh
2. run the reactingParcelFilmFoam
Then it show the error:
--> FOAM FATAL ERROR:
Cannot find file "points" in directory "wallFilmRegion/polyMesh" in times 0 down to constant
From function Time::findInstance(const fileName&, const word&, const IOobject::readOption, const word&)
in file db/Time/findInstance.C at line 188.
FOAM exiting
So, I'am thinking maybe I should first create wallFilmRegion. But I don't know the command or steps to do.
Can anyone find out where the problem is?
Thanks.
Xiaoxia
huxiaoxia is offline   Reply With Quote
Old   August 4, 2011, 13:00
huxiaoxia
I'v solved the problem. If anyone wants to know how to solve it, let me know.
Old   August 29, 2011, 18:14
Palmertime
palmertime is on a distinguished road
Can you share the resolution to this issue?
thanks,
palmertime is offline   Reply With Quote
Old   August 29, 2011, 19:36
Default Openfoam 2.0.0
huxiaoxia
You just open the file Allrun.pre and follow the steps.
Old   July 26, 2013, 07:03
Default how to overcome from this error
sonu
yash.aesi is on a distinguished road
helo ,
i am also having same problem when i tried to run the fireFoam example then the error on screen is:
FOAM FATAL ERROR:
Cannot find file "points" in directory "panelRegion/polyMesh" in times 0 down to constant
in file db/Time/findInstance.C at line 203
So can you guide me how to resolve this problem ?
yash.aesi is offline   Reply With Quote
Old   August 16, 2013, 11:42
Retired Super Moderator
Bruno Santos
Greetings to all!
For future reference:
  • The tutorial in question is "lagrangian/reactingParcelFilmFoam/rivuletPanel".
  • To run the case, go into the case folder "rivuletPanel" and run:
    ./Allrun
  • To clean up the case, so that you can restart again, run:
    ./Allclean
  • Last but not least, for more information, open your favourite text editor and open the files that are in this tutorial folder, so that you can learn how the scripts "Allrun", "Allrun.pre" and "Allclean" work. If you're feeling lazy, you can also see the file contents online, e.g. for OpenFOAM 2.2.x: https://github.com/OpenFOAM/OpenFOAM...m/rivuletPanel
Best regards,
Bruno
Old   August 22, 2016, 02:49
zhoubiao
zhoubiao1088 is on a distinguished road
Originally Posted by yash.aesi View Post
helo ,
FOAM FATAL ERROR:
could you share the method to solve this problems?
zhoubiao1088 is offline   Reply With Quote
