OpenFOAM on deux pc
Like Tree2Likes
  • 2 Post By calim_cfd
Old   April 12, 2012, 06:22
Default OpenFOAM on two pc
Rider is on a distinguished road
Anybody has already executed a parallel simulation on two pc ?
Currently, I execute my simulation in multi-core on one pc, but it's apparently not enough ...
Thanks
Rider is offline   Reply With Quote
Old   April 12, 2012, 06:40
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Yes, I would say anybody here has already ran a parallel simulation…
lovecraft22 is offline   Reply With Quote
Old   April 12, 2012, 06:47
Sorry, this is not what I meant
I just would like an help to realise this type of configuration
Old   April 12, 2012, 07:12
lore
First you need to decompose your domain using decomposePar (see decomposeParDict) among your processors, so if you have 2 processor you'll decompose your domain in 2 subparts.
Then, use mpirun to run any command you want. For example, if you want to run snappyHexMes in parallel you'll need to run:
mpirun -np 2 snappyHexMesh -parallel
where 2 is, again, the number of your processors. At the end run reconstructPar.
Have a look at par "2.3.11 Running in parallel" of the user manual.
Old   April 12, 2012, 08:05
Thanks for your answer, but it's not really my question. I know how to realise a simulation in multi-core. Currently, I'm using it on 4 cores and on 8 cores. Personnaly, I use the command "FoamJob" but it's the same method as "mpirun"
My problem is to use two computeur for the same simulation, so use the 4 cores of the PC n°1 and the 8 cores of the pc n°2.
Old   April 12, 2012, 08:50
lore
Sorry, my mistake…
I found this one, don't know if it may be of any help…
http://www.divms.uiowa.edu/~jni/HowT...dAClusterG.pdf
Old   April 12, 2012, 08:52
Retired Super Moderator
Bruno Santos
Greetings to all!
@Rider: you're already on the right track, by using foamJob. All you need is to create a file named "machines" on the base folder of your case.
With open source, when in doubt, check the code!
As for the format of the "machines" file, if using Open-MPI: http://www.open-mpi.org/faq/?categor...imple-spmd-run
Best regards,
Bruno
Old   April 12, 2012, 09:11
Originally Posted by lovecraft22 View Post
Sorry, my mistake…
No problem. A forum is a platform of exchange.
@wyldckat
Thanks for your answer. Have you an example of "machines" file ?
How the computers should being connected ?
Old   April 13, 2012, 03:20
Bruno Santos
Hi Rider,
The example was on the link I posted and the connection is simple: both machine should reflect the same exact installation structure. And be on the same network, namely the following command should work in both directions:
ping the_other_machine_IP_or_name
Best regards,
Bruno
Old   April 13, 2012, 04:19
In fact, I don't really understand this example.
I don't see how to parameterise the two computers to share the simulation. Moreover, the fisrt computer has 4 cores and the seconde has 8 cores.
Can you detail the procedure in simple words ... for a basic simpleFoam simulation
Thanks for your help !
Old   April 13, 2012, 04:26
Bruno Santos
... OK... Example "machines" file:
machine1 slots=4 max-slots=4
machine2 slots=8 max-slots=8
I can't go into more details right now. Good luck!
Old   April 14, 2012, 07:32
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
In addition to the machinefile you also will need to have the case and OpenFoam in a shared directory (or a exact copy of both on the slave, but this might be impratical) and passwordless ssh access on the slave node.
You might find a nice howto on this subject on the clustermonkey website (that's how i learnt).
http://www.leadingedge.it/
Naval architecture and CFD consultancy
sail is offline   Reply With Quote
Old   April 17, 2012, 16:10
calim_cfd's Avatar
mauricio
calim_cfd is on a distinguished road
hi thou the user's guide has all the info you need you may get stuck while setting the case.. this is what you gotta do:
1:have the same OF version properly installed on all pcs along with permissions
2: create a machine files like this
192.168.15.xx cpu=n1
192.168.15.xx cpu=n2
where nx is the number of cores on each cpu.. this file can be fancier..
3: edit this file on the host machine, from where you're firing the job : /etc/hosts
and add all nodes on it.. like this:
192.xx.xx.xx name1 #
192.xx.xx.xx name2 #
4: edit decomposepardict like this (the setting are for 5 cores, set it accordingly):
decomposeParDict:
#ofSubdomains 5
scotchCoeffs
processorWeights
1
1
1
1
1
distributed yes;
roots 4
"/disk1/test/noh1"
"/disk1/test/noh2"
"/home/noh3"
"/home/noh4"
note that the paths given above are only needed if you want each pc to store the files on it, instead of only using its cpu power. Also you only list the the slave nodes (4 if you're using 5). In this case you'd run the analysis from the direc: "/disk1/test/noh0"
most important thing is that inside each folder, here named "nohx" you have the exact same decomposed case, and i mean you got the folders 0, constant, system, processor* etc inside these "nohx" folders
5: selectively get the files back into the host/master machine through the command:
user@pc:/disk1/test/rec> scp -r user2@pcx:~/noh4/processor4 rec/
i guess you can figure out how to use this command
hope it helps!
wyldckat and BlnPhoenix like this.
Best Regards
/calim
"Elune will grant us the strength"
Last edited by calim_cfd; May 6, 2012 at 10:31. Reason: reminder of decomposed case
calim_cfd is offline   Reply With Quote
Old   August 29, 2016, 17:53
Danny Jierian
djierian is on a distinguished road
Mauricio,
To do this, how are the two computers linked? Is a cross cable sufficient? or do I need an NFS and passworldess SSH as I've seen elsewhere on these forums.
Thanks,
Danny
djierian is offline   Reply With Quote
Old   August 30, 2016, 06:29
calim_cfd's Avatar
mauricio
hi Danny.
It's been a while since i've ran some simulations using more than one machine. Not sure if things haven't changed. Probably not, lol.
So, from what i can remember, i guess you don't need to setup a new file system. The cabling should be enough. I guess you could, even though, depending on how you work on linux OSs this won't change much.
It suffices that node0 sees has access and you have write and reading permissions for the other folders at the other nodes. Also, don't forget to setup the /etc/host file with the address of the nodes and the decomposePardict with the case locations.
Nonetheless, you should watch for a network bottleneck when you use 100mb or even 1gb networks. Your performance may not be that great, assuming you have some hardcore hardware, aka, cluster lol
gl
Best Regards
/calim
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
