blockMesh & negative volume error
Old   April 21, 2013, 06:28
Default blockMesh & negative volume error
Sasan Ghomi
sasanghomi is on a distinguished road
Hi Dear foamers,
I created the mesh by using blockMesh and after checkMesh I had a negative volume error..
Can anyone explain how can I solve this problem ?
| \\      /  F ield         | OpenFOAM Extend Project: Open source CFD        |
|  \\    /   O peration     | Version:  1.6-ext                               |
|   \\  /    A nd           | Web:      www.extend-project.de                 |
Build  : 1.6-ext-959ec266ba5c
Exec   : checkMesh
Date   : Apr 21 2013
Time   : 14:54:37
Host   : sasan-Inspiron-N5110
PID    : 15795
Case   : /home/sasan/Desktop/engine-blockMesh
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    all points:           172769
    live points:           172769
    all faces:            484260
    live faces:            484260
    internal faces:   451740
    cells:            156000
    boundary patches: 22
    point zones:      2
    face zones:       13
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     156000
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
   *Number of regions: 5
    The mesh has multiple regions which are not connected by any face.
  <<Writing region information to "0/cellToRegion"
Checking patch topology for multiply connected surfaces ...
    Patch               Faces    Points   Surface topology
    presin              800      861      ok (non-closed singly connected)
    presout             800      861      ok (non-closed singly connected)
    symmetry            6600     7147     ok (non-closed singly connected)
    cylinderHead        2400     2521     ok (non-closed singly connected)
    intakePort          1800     1886     ok (non-closed singly connected)
    exhaustPort         1800     1886     ok (non-closed singly connected)
    liner               800      891      ok (non-closed singly connected)
    valveStem1          1680     1763     ok (non-closed singly connected)
    valveStem2          1680     1763     ok (non-closed singly connected)
    piston              5600     5843     ok (non-closed singly connected)
    valve1              1000     1066     ok (non-closed singly connected)
    valve2              1600     1661     ok (non-closed singly connected)
    valve3              1000     1066     ok (non-closed singly connected)
    valve4              1600     1661     ok (non-closed singly connected)
    valveCurtainCyl1    400      451      ok (non-closed singly connected)
    valveCurtainPort1   1280     1404     ok (non-closed singly connected)
    valveCurtainCyl2    400      451      ok (non-closed singly connected)
    valveCurtainPort2   1280     1404     ok (non-closed singly connected)
    valveDetachCyl1     0        0        ok (empty)
    valveDetachPort1    0        0        ok (empty)
    valveDetachCyl2     0        0        ok (empty)
    valveDetachPort2    0        0        ok (empty)
Checking geometry...
    This is a 3-D mesh
    Overall domain bounding box (-0.05 0 -0.00712619) (0.05 0.05 0.0219694)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Mesh (non-empty, non-wedge) dimensions 3
    Boundary openness (-2.63084e-18 -8.37796e-15 2.66712e-16) Threshold = 1e-06 OK.
 ***High aspect ratio cells found, Max aspect ratio: 16856.8, number of cells 156000 Threshold = 1000
  Writing 156000 cells with high aspect ratio to set highAspectRatioCells
    Minumum face area = 3.52505e-08. Maximum face area = 1.99753e-06.  Face area magnitudes OK.
 ***Zero or negative cell volume detected.  Minimum negative volume: -1.42348e-09, Number of negative volume cells: 156000
  Writing 156000 zero volume cells to set zeroVolumeCells
Floating point exception (core dumped)
I attached several pictures of the mesh.
I appreciate your help.
Thanks and best regards.
Sasan.
sasanghomi is offline   Reply With Quote
Old   April 21, 2013, 09:59
Nima Samkhaniani
nimasam is on a distinguished road
it returns to the ordering of block, you can see negative volume as you create your mesh by blockMesh, it shows negative volume as warnings
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   April 22, 2013, 03:22
Sasan Ghomi
Hi Dr.sam,
thanks for your reply.
Can you say how can I overcome this error?
I should modify the vertices? Or I should change the ordering of points in construction of blocks??
Thanks and best regards,
Sasan
Old   April 22, 2013, 04:22
Nima Samkhaniani
Hi Dear sasan
in some simple cases when i see this warning in blockMesh i change the order of vertices, but maybe there are other ways to solve it
Old   August 31, 2016, 02:34
Viraj Belekar
viraj20feb is on a distinguished road
Hello Mr. Nima,
I imported my mesh from Gmsh (http://www.cfd-online.com/Forums/ope...ecks-fail.html)
still I am facing the problem of Zero or negative volume. Can you please tell me how to solve it?
Thank you
viraj20feb is offline   Reply With Quote
Old   September 1, 2016, 03:01
Nima Samkhaniani
it is due to wrong face orientation in the grid. so you should change it. consider either clockwise or counter clock wise for the faces.
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
