February 23, 2017, 12:07 |
blockMesh generates under determinants cell
Rep Power: 11 |
Hello everyone,
I'm trying to simulate an external incompressible flow but the blockMeshDict in attached generates thousands of under determinant cells. Someone can resolve this issue? thank you in advance Andrea |
February 24, 2017, 11:23 |
Saideep
Rep Power: 11 |
it is extremely difficult to point where the error comes from. Can you attach a figure of what your trying to model?
February 25, 2017, 14:29 |
#3 | |
Rep Power: 11 |
thank you for your reply, I'm trying to simulate a flow around a magnetometer in order to evaluate it's drag. It's an incompressible turbulent steadystate simulation and I'm using simpleFoam but during SHM's quality evaluation I saw that the under determinant cells number was every time constant, so I tryed a checkmesh (all topology -all geometry) immediately after Blockmesh and I noted that the problem was due to blockMesh. I don't know why blockMesh generates so many under determinant cells, any idea? thank you |
February 27, 2017, 12:17 |
Rep Power: 11 |
someone who can help me?
February 28, 2017, 03:20 |
Rep Power: 12 |
Hello fluxent,
I am not very familiar with blockMesh. Can you share a picture of your mesh with the bad cells highlighted for example in paraView. Best regards, Kate |
February 28, 2017, 04:55 |
#6 | |
Rep Power: 11 |
I tried to highlight those cells with paraview but no one of them was visible, like if they don't exist. Flux |
February 28, 2017, 05:05 |
Rep Power: 12 |
You tried with
foamToVTK -cellSet underdeterminedCells |
February 28, 2017, 05:41 |
Rep Power: 11 |
Yes but no result
February 28, 2017, 08:02 |
#9 |
Rep Power: 12 |
Do you get the corresponding underdeterminedCells file in the postProcessing folder after executing the command?
If not, do you get a error message? |
February 28, 2017, 20:09 |
#10 |
Rep Power: 15 |
Have you tried running your simulation and see if it runs without diverging? While underdeterminedCells might crop up, it doesn't necessarily mean that it will interfere with your simulation run/results. Cheers, Antimony |
March 3, 2017, 16:08 |
#11 | |
Rep Power: 11 |
I follow yours suggestion, the simulation converge, but the reason for why blockmesh generates those underdeterminant cells remains unknown. kind regards |
March 5, 2017, 21:58 |
#12 |
Rep Power: 15 |
I took a look at your blockMeshDict and noticed that the grading ratios that you had, among others, were 0.01 and 100. So it is quite possible in your mesh that there are regions which have extremely small cells and regions were there are large cells leading to underdetermined cells. Cheers, Antimony |
March 10, 2017, 03:15 |
#13 |
Rep Power: 11 |
Thank you antimony I will try as soon as possible then write the results here.
Kind regards |
Display Modes | |
How to use "translation" in solidBodyMotionFunction in OpenFOAM | rupesh_w | OpenFOAM Running, Solving & CFD | 5 | August 16, 2016 04:27 |
Journal file error | magicalmarshmallow | FLUENT | 3 | April 4, 2014 12:25 |
[Workbench] Creation of Cell Zones for processing in FLUENT | kailingkk | ANSYS Meshing & Geometry | 0 | October 5, 2013 05:09 |
monitoring cell | Jane | Siemens | 2 | March 4, 2004 21:01 |
cell to cell relation | CMB | Siemens | 1 | December 4, 2003 04:05 |
