Difference between mass-flow inlet and velocity inlet
Like Tree2Likes
  • 2 Post By Saideep
Old   June 13, 2016, 06:00
Default Difference between mass-flow inlet and velocity inlet
rekap is on a distinguished road
I am using Simflow (an OpenFOAM gui).
I am modeling two incompressible fluids flowing in a relatively complex channel in order to see how they mix.
I run a simulation using the mass-flow inlet boundary condition with a flow rate, let's say Q. Then I run a simulation using the velocity inlet boundary condition with a velocity v calculated as Q/A where A is the section of the channel. Then I should expect the same result. However the simulations give different results.
Can anyone explain why? Which is the difference between the mass-flow inlet and velocity inlet boundary conditions?
Thank you.
rekap is offline   Reply With Quote
Old   June 13, 2016, 08:06
Saideep
Saideep is on a distinguished road
I mostly use a constant velocity inlet bc but when you say mass inlet, I am guessing that the density of fluid comes into play as well.
That is, you need to think in terms of kg/s rather than in m3/s.
I have no idea about the gui version of OF but if you have a check for your units that should say if what i told is true{kg/s} or not{m3/s}.
Saideep
Saideep is offline   Reply With Quote
Old   June 13, 2016, 09:24
When I use the mass-flow inlet boundary condition, the unit for the inlet is [m3/s]. Maybe the gui version use the density for computing the mass flow rate.
I found out on the web that for Fluent the velocity inlet bc is recommended for incompressible flows while mass flow inlet bc is recommended for compressible flows.
Do you think this is valid also in OpenFOAM? If so, can I say this is the reason why I have different simulation results?
rekap
Old   June 13, 2016, 11:45
Saideep
For in-compressible flow density isn't varying. So, fixed flux/ fixed velocity is good enough. Even fixed mass should not be causing any sort of problem.
When you go for compressible flows, there are few parameters on which the density depends.
One example of a general case, at the inlet you fix mass/ velocity and allow pressure to vary accordingly by a Neumann condition. When your pressure is fluctuating your density also varies. (ultimately your mass flow is varying over time). So, fixing the mass flow[kg/s] is a better condition than fixing velocity.
I use in-compressible so if I am wrong any correction is welcome.
Saideep
soheil_r7 and ViniSpark like this.
Old   June 14, 2016, 04:18
Thank you for your answer, now it's clearer.
rekap
Old   October 17, 2016, 08:07
Default boundary problem
rihen full
nehir is on a distinguished road
I want to solve a ventilated wall problem. but ı cannot describe boundary condition esspecially for air. there is no velocity or mass for air. natural convection.
how can describe boundary inlet and outle
nehir is offline   Reply With Quote
boundary conditions, inlet bc, massflow bc, simflow, velocity bc
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
What's the difference between velocity inlet and mass flow inlet? soheil.e.nia FLUENT 5 August 20, 2014 14:08
How to define a fixed velocity for a given mass flow rate on inlet mqasimali FLUENT 2 April 12, 2013 17:24
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
