October 19, 2016, 14:08 |
Pinj profile in sprayfoam, openFoam 2.4.0
Giuseppe
Hi everyone,
I'm studying a spray without combustion. I need to set a injection pressure profile, but just after first iteration, I receive a error. the Pinj table is: (0.00000 0.00000) (0.00010 6000000) (0.00180 6000000) (0.00190 0.00000) (0.00500 0.00000) the pressure in the chamber is 0.2MPa. this is the error: #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::ConeNozzleInjection<Foam::KinematicCloud<Foa m::Cloud<Foam::SprayParcel<Foam::ReactingParcel<Fo am::ThermoParcel<Foam::KinematicParcel<Foam:arti cle> > > > > > >::setProperties(int, int, double, Foam::SprayParcel<Foam::ReactingParcel<Foam::Therm oParcel<Foam::KinematicParcel<Foam:article> > > >&) at ??:? #4 ? at ??:? #5 ? at ??:? #6 ? at ??:? #7 ? at ??:? #8 ? at ??:? #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 ? at ??:? Floating point exception (core dumped) --------------------------------------------------------------------------------------- I think that the error is due to this formula: U = sqrt(2*(Pinj - Pamb)/rho) because (Pinj-Pamb) is < 0 so the question is, can I set a Pinj=0? because I have to set in the model this pressure profile, look at attached. help me! |
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days | joegi.geo | OpenFOAM Announcements from Other Sources | 0 | October 1, 2016 19:20 |
[OpenFOAM.org] OpenFOAM 2.4.0 and Fedora 22: error building CGAL | macelee | OpenFOAM Installation | 4 | April 2, 2016 22:01 |
OpenFOAM Training: Programming CFD Course 12-13 and 19-20 April 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 14, 2016 10:19 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
