[Sponsors] | |||||
Harshal Akolekar
Rep Power: 11 ![]() |
Hi everyone,
I am trying to run a simulation around using rhoPimpleFoam. However, as soon as I run this I get the following error message. --> FOAM FATAL ERROR: Arguments of max have different dimensions dimensions : [0 0 0 0 0 0 0] and [1 -3 0 0 0 0 0] From function max(const dimensionSet&, const dimensionSet&) in file dimensionSet/dimensionSet.C at line 231. How can this be dealt with?Thank you. Regards, Harshal |
Rep Power: 13 ![]() |
Hey,
have you modified the code ? There could be an inconsistency in your implementation ! Otherwise there seems to be a setup mistake in your case (most probably related to dimensions). Itīs a bit hard to tell from far away whats specificly going wrong there. |
Harshal Akolekar
Hi everyone,
I found the answer. The dimensions for the pressure file are different for the incompressible case and the compressible case. [0 2 -2 0 0 0 0] - incompressible [1 -1 -2 0 0 0 0] - compressible That was causing the above error. Regards, |
Hi all,
I have edited code in twoPhaseEulerFoam and am getting a similar error. The error is as follows:- Code:
LHS and RHS of + have different dimensions
dimensions : [0 0 0 0 0 0 0] + [0 0 -1 0 0 0 0]
From function Foam::dimensionSet Foam::operator+(const Foam::dimensionSet&, const Foam::dimensionSet&)
in file dimensionSet/dimensionSet.C at line 489.
FOAM aborting
#0 Foam::error::printStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam::operator+(Foam::dimensionSet const&, Foam::dimensionSet const&) at ??:?
#3 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator+<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
#4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator+<Foam::fvPatchField, Foam::volMesh>(double const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
#5 ? at ??:?
#6 __libc_start_main in "/lib64/libc.so.6"
#7 ? at ??:?
/home/svachha/.lsbatch/1547920500.668919.shell: line 18: 27791 Aborted
How do I rectify the error Your help in this matter is greatly appreciated. Thanks and Regards, Shantanu Code:
//#include "Random.H"
//#include "StochasticDispersionRAS.H"
#include "contErrs.H"
Info<< "Constructing momentum equations" << endl;
MRF.correctBoundaryVelocity(U1);
MRF.correctBoundaryVelocity(U2);
MRF.correctBoundaryVelocity(U);
fvVectorMatrix U1Eqn(U1, rho1.dimensions()*U1.dimensions()*dimVol/dimTime);
fvVectorMatrix U2Eqn(U2, rho2.dimensions()*U2.dimensions()*dimVol/dimTime);
dimensionedScalar dimen
"dimen",
dimensionSet(0,1,1,0,0,0,0),
scalar(1.0)
dimensionedScalar dimen1
"dimen1",
dimensionSet(0,1,2,0,0,0,0),
scalar(1.0)
volVectorField gr_alpha = fvc::grad(alpha2);
volTensorField grU_2 = fvc::grad(U2);
volScalarField sc = grU_2 && (grU_2 + grU_2.T());
const scalar csid = 25;
const scalar a = 4e-6;
const scalar eps = 0.206;
//Lift force
volScalarField up = .1629+ (.2088/(.1476+(Foam::sqrt(sc))));
const scalar cl = 1.2;
volVectorField fsid = U2; // copy of the field;
volVectorField fl = U2;
volScalarField dis = wallDist(mesh).y();
volVectorField ncap = wallDist(mesh).n();
//Info<<"data="<<dis<<"\n"<<endl;
//Info<<"ncap="<<ncap<<"\n"<<endl;
Random rnm;
forAll(fsid, cellI)
scalar rn = rnm.GaussNormal<scalar>();
fsid[cellI][0] = (Foam::sqrt(sc[cellI]))*alpha2[cellI]*a*eps*rn*csid*-((gr_alpha[cellI][0])/(mag((gr_alpha[cellI]))+ROOTSMALL));//*dimen;
fsid[cellI][1] = (Foam::sqrt(sc[cellI]))*alpha2[cellI]*a*eps*rn*csid*-((gr_alpha[cellI][1])/(mag((gr_alpha[cellI]))+ROOTSMALL));//*dimen;
fsid[cellI][2] = (Foam::sqrt(sc[cellI]))*alpha2[cellI]*a*eps*rn*csid*-((gr_alpha[cellI][2])/(mag((gr_alpha[cellI]))+ROOTSMALL));//*dimen;
forAll(fl,cellI)
fl[cellI][0] = ((cl*(up[cellI])*(sc[cellI])*a*a*a)/((dis[cellI])+ROOTSMALL))*(ncap[cellI][0]);//*dimen1;
fl[cellI][1] = ((cl*(up[cellI])*(sc[cellI])*a*a*a)/((dis[cellI])+ROOTSMALL))*(ncap[cellI][1]);//*dimen1;
fl[cellI][2] = ((cl*(up[cellI])*(sc[cellI])*a*a*a)/((dis[cellI])+ROOTSMALL))*(ncap[cellI][2]);//*dimen1;
volScalarField Kd(fluid.Kd());
volScalarField Vm(fluid.Vm());
U1Eqn =
fvm::ddt(alpha1, rho1, U1) + fvm::div(alphaRhoPhi1, U1)
- fvm::Sp(contErr1, U1)
+ MRF.DDt(alpha1*rho1 + Vm, U1)
+ phase1.turbulence().divDevRhoReff(U1)
- Vm
fvm::ddt(U1)
+ fvm::div(phi1, U1)
- fvm::Sp(fvc::div(phi1), U1)
- DDtU2
+ fvOptions(alpha1, rho1, U1)
U1Eqn.relax();
U1Eqn += fvm::Sp(Kd, U1);
fvOptions.constrain(U1Eqn);
U1.correctBoundaryConditions();
fvOptions.correct(U1);
U2Eqn =
fvm::ddt(alpha2, rho2, U2) + fvm::div(alphaRhoPhi2, U2)
- fvm::Sp(contErr2, U2)
+ MRF.DDt(alpha2*rho2 + Vm, U2)
+ phase2.turbulence().divDevRhoReff(U2)
- Vm
fvm::ddt(U2)
+ fvm::div(phi2, U2)
- fvm::Sp(fvc::div(phi2), U2)
- DDtU1 - fsid - fl
+ fvOptions(alpha2, rho2, U2)
U2Eqn.relax();
U2Eqn += fvm::Sp(Kd, U2);
fvOptions.constrain(U2Eqn);
U2.correctBoundaryConditions();
fvOptions.correct(U2);
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| UNIGE February 13th-17th - 2107. OpenFOAM advaced training days | joegi.geo | OpenFOAM Announcements from Other Sources | 0 | October 1, 2016 20:20 |
| [Other] mesh spatial dimension in OpenFOAM | jr33 | OpenFOAM Meshing & Mesh Conversion | 4 | May 23, 2016 12:59 |
| OpenFOAM Training Beijing 22-26 Aug 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | May 3, 2016 05:57 |
| Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
| OpenFOAM Training in Europe and USA | hjasak | OpenFOAM | 0 | August 8, 2008 06:33 |
