October 24, 2016, 08:10 |
generating case file for post processing.
Jun
Rep Power: 9 |
Hi guys, im fairly new in OpenFOAM. i used to work with ANSYS FLUENT AND CFX with basic knowledge on them. but i would like to learn more about OF and try it out.
Im currently running windows 10, got the installation running smooth, but one thing that confuses me is that where do i see the files in my windows directory? i dont understand how they actually copy the files from VM and it will show up in the common username directory? Plus the new windows OF doesn't run with VM but through docker and OpenFOAM_Start. i have a snapshot of the OF terminal. i managed to load the tutorial cavity case file, get the blockMesh, checkMesh, and icoFoam. but to edit and post process them, what are the steps? i've been trying to figure it out for 2 solid days. no results... would appreciate any help from all of you kind OpenFOAMers. below is a snapshot of my progress so far till icoFoam regards, Jun Last edited by JX-; October 24, 2016 at 08:14. Reason: upload picture |
October 24, 2016, 21:01 |
Rep Power: 15 |
You can create a dummy file called case.foam in your case folder. Open Paraview, and navigate to your case folder and open case.foam. You should be able to view your simulation results there. Cheers, Antimony |
October 25, 2016, 01:34 |
Jun
Rep Power: 9 |
Well, thats the thing, whats a case folder? I cant seem to locate any folders physically in my windows explorer...
October 25, 2016, 02:14 |
Rep Power: 15 |
The case folder is the one that contains your time sub-folders, the 'constant' sub-folder and the 'system' sub-folder. It is the location from which you called your blockMesh, checkMesh and icoFoam commands... Cheers, Antimony |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X | gschaider | OpenFOAM Installation | 136 | October 10, 2017 17:25 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 03:04 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
