Courant number in OpenFOAM
When do i need the folowing equation?
https://openfoamwiki.net/images/math...d5a50a961b.png And what does it mean? is there Delta V the cell volume and Delta S a area from the cell surface? What means the f in sum_f. Could somebody explain it with a cell with the size a*b*c found it on: https://openfoamwiki.net/index.php/Co and also in CourantNo.C Code:
The Courant number provides a stability criterion, which is especially important if you use an explicit time scheme. If , you may expect your simulation to diverge. See:
https://en.wikipedia.org/wiki/Couran...Lewy_condition Intuitively, it says that within a given timestep , fluid may flow a distance of one cell at most (if ). In practice, we limit the Courant number to be smaller than 0.1~0.5. In your equation , where is the surface area of a face. Plugging in your , you will find that (for example). This expression should be evaluated for each face , because (again, see the link above) in more dimensions you should sum the contributions of each dimension. The factor 0.5 is presumably there to prevent double-counting opposite faces (west and east), as they belong to the same direction. When do you need it? You don't. In controlDict, set Code:
adjustTimeStep yes; |
Well this is everything i need t know. Thank you.
The factor of 0.5 is just because we summed over the magnitude of the phi, since the phi_in hast to be equal to phi_out. Is that correct?
icoFoam has not this feautre implemented, if you want "icoFoam with adjustable time" you should run pimpleFoam in ico foam setting and pimple has adjustable time build in. best regards |
