Question about rhoCentralFoam and rhoPimpleFoam?
Like Tree16Likes
  • 9 Post By iLyrics
  • 3 Post By usv001
  • 4 Post By iLyrics
Old   June 30, 2016, 11:36
Default Question about rhoCentralFoam and rhoPimpleFoam?
Lee Yachao
iLyrics is on a distinguished road
Hello foamers. I'm now making an effort to generating turbulence inflow in for a flat in the supersonic flow. At the very first, I was doing the test case by the rhoPimpleFoam. The results were acceptable. However, when I turned to the rhoCentralFoam, I cann't reproduce the same results. The puzzle troubled me a lot. I just can't find out where is going wrong. In fact, I just modified the boundary condition of the inlet plane, namely U, T and rho field. Any suggestions?
iLyrics is offline   Reply With Quote
Old   June 30, 2016, 11:38
Lee Yachao
How to attatch the picture?
Old   September 4, 2016, 11:28
Lee Yachao
Let's answer myself. As to my experience, the rhoCentralFoam solver is adopting a dissipative scheme(TVD/NVD), while the the rhoPimpleFoam is adoping a non-dissipative scheme(linear scheme). So you can use the rhoCentralFoam solver to deal with the discountinuity problem, but you can't expect it to generate turbulence. The rhoPimpleFoam solver is just the opposite side.
Old   September 7, 2016, 05:10
g.freeman is on a distinguished road
That's the answer
g.freeman is offline   Reply With Quote
Old   December 10, 2016, 03:24
Default rhoPimpleFoam vs rhoCentralFoam - LES, turbulence
usv001 is on a distinguished road
Hello all,
I am faced with the same dilemma as iLyrics. I have implemented two different synthetic turbulence generation methods. I tried to test them using rhoCentralFoam and found that the turbulence dissipated very fast but quite well preserved in rhoPimpleFoam (see picture).
I find the answer given by iLyrics quite reasonable but I need to use rhoCentralFoam since I want to test cases with shocks. So, is there anyway out?
Regards,
USV
usv001 is offline   Reply With Quote
Old   December 10, 2016, 04:28
Default Suggestions
Lee Yachao
The key point is that you should adopt a low dissipation scheme, which could deal with shock wave and resolve the turbulence deep into the wall boundary layer.
Most importantly, the grid should meet some requirements, especially combined with LES methods. So realization of turbulence inflow generation within the OpenFOAM frame is not an easy case.
Old   December 10, 2016, 07:57
Hello Lee,
Thanks for the quick reply. So, do you think that if I were to use higher order schemes with proper shock capturing (e.g. ENO, WENO), this problem shouldn't arise?
The mesh I am using now is close to DNS requirements, actually. So, I believe mesh shouldn't be a problem.
Regards,
USV
rhocentralfoam, tubulence inflow
how to make rhoCentralFoam to write continuity residuals? immortality OpenFOAM Running, Solving & CFD 6 April 18, 2018 03:56
rhoCentralFoam flat plate boundary layer issues laurensvd OpenFOAM Running, Solving & CFD 6 September 13, 2013 03:10
momentum equation in rhoCentralFoam immortality OpenFOAM Running, Solving & CFD 0 June 12, 2013 06:22
how to modify rhoCentralFoam to write continuity residuals? immortality OpenFOAM Programming & Development 0 May 1, 2013 12:44
is sonicFoam better in convergence than rhoPimplefoam or rhoCentralFoam? immortality OpenFOAM Running, Solving & CFD 1 February 11, 2013 22:26
