How can you design a Abrams cone in Openfoam
Old   December 3, 2016, 09:47
Default How can you design a Abrams cone in Openfoam
Mrin
whitelotus21 is on a distinguished road
I am an openfoam beginner and I have to design a Abrams cone which is a cone with the top part cut, so the top radius is 50 mm and the bottom diameter is 100 mm and the height is 300 mm. And I have to mesh it. How do I go about this? How will this show on Paraview?
whitelotus21 is offline   Reply With Quote
Old   December 4, 2016, 06:33
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
There are several possibilities for you:
  • use blockMesh
  • use a CAD system, draw it, export as STL and mesh with snappyHexMesh
  • use a CAD system, draw it, export as STEP and mesh with Salome
  • use a CAD system, draw it, export as STL and use whatever mesher you want if you can convert the generated mesh to OpenFOAM (check out the mesh conversion stuff in the UserGuide)
  • After converting, you can check the result in ParaView
If you don't know how to do anything, I recommend you to read the User-Guide. Good luck.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
openfoam 2.0.x, paraview
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 05:40
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 03:19
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 03:18
OpenFOAM Foundation releases OpenFOAMŪ 3.0.0 CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 1 November 7, 2015 15:16
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
