Foam::error::printStack(Foam::Ostream&) at ??:? ///// pimpleDyMFoam
Like Tree8Likes
  • 5 Post By chegdan
  • 2 Post By chegdan
  • 1 Post By j_moulton
Old   December 7, 2016, 08:54
Default Foam::error::printStack(Foam::Ostream&) at ??:? ///// pimpleDyMFoam
bye bye my blue
bye bye my blue is an unknown quantity at this point
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam:ow3(Foam::Field<double>&, Foam::UList<double> const&) at ??:?
#4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:ow3<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#5 Foam::RASModels::SpalartAllmaras<Foam::Incompressi bleTurbulenceModel<Foam::transportModel> >::fv1(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:?
#6 Foam::RASModels::SpalartAllmaras<Foam::Incompressi bleTurbulenceModel<Foam::transportModel> >::correct() at ??:?
#7 ? at ??:?
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9 ? at ??:?
Floating point exception (core dumped)
I don't know how to solve it .....
and I attached B.C , checkMesh output and etc..
please help me ToT
thanks.
bye bye my blue is offline   Reply With Quote
Old   December 7, 2016, 08:59
Default + other files..
bye bye my blue
log.pimpledymfoam has big size, so i modified it
Old   December 13, 2016, 19:01
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
First of all, this is a very common error (i.e. the divide by zero) and is not necessarily easy to figure out. I did notice that you fix all the values of nuTilda in your simulation so you might want to go back and look through the tutorials or search the forum on how to correctly set the nutilda boundary conditions. As for how to proceed, i would start first with a much simpler strategy. Though your ultimate goal may be a turbulent, transient, dynamic mesh case i would:
  • Start with a steady simulation. Lower the flow rate to a laminar level and turn off turbulence all together to make sure that you have pressure and velocity BCs setup correctly (i have not looked at yours to confirm yet). Use upwind on everything (because it is bounded and first order).
  • Try a higher flow rate (still steady) with turbulence to get your turbulence model BCs setup correctly (still first order schemes)
  • Try a higher flowrate, but transient case with no dynamic mesh to see how the time stepping influences/changes during the simulation (still first order schemes)
  • Try the dynamic mesh case with very conservative settings (ie. if it rotates, make it rotate slow), as this will help you see if your ami (as it rotates) is causing issues (e.g. overlapping faces).
  • Try at a real condition with first order schemes, then try to move to higher order schemes. use function objects and in-situ probes to evaluate your solution as it is running to see if you are within acceptable ranges.
  • Say something nice to your computer or cluster to make it not crash so often.
Overall, start simple and build up. Good luck and I would also look at
How to give enough info to get help
and provide a bit more information next time e.g. a complete zipped case or a link to a dropbox so others can download it and help.
chegdan is offline   Reply With Quote
Old   December 14, 2016, 06:24
hxaxtma is on a distinguished road
Without knowing your case I can just assume what happened, anyway here are some hints
0) Everything what chegdan said
1): Check your BCs for p and U if they are set up properly.
- in your p File you set the pressure for inlet and oulet to 0! Is this by purpose?
Normally you use for U inlet: fixedValue and outlet zeroGradient and for pressure inlet zeroGrdianet and outlet fixedValue
2) Next: your checkMesh shows up with 207 cells < 0.001 determinant. Check were these cells are situated
3) Observe what happens in your flow field for pressure and velocity with paraview.
hxaxtma is offline   Reply With Quote
Old   February 17, 2017, 17:31
Jeremy
j_moulton is on a distinguished road
Hi everyone, receiving a similar message for what I think is a simple case (attempting incompressible, laminar flow in a pipe):
#3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#5 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#6 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
#7 ? at ??:?
#9 ? at ??:?
I have been Frankensteining together some code and I thought I was close. Most of the case files are attached as .zips. Please help me out with some feedback! Thanks.
j_moulton is offline   Reply With Quote
Old   February 17, 2017, 17:48
Daniel P. Combest
Jeremy,
After a quick look at your files, I can try suggest a few things. I'm assuming that you are using icoFoam, pisoFoam, pimpleFoam, or simpleFoam to perform your simulations. If so, this error can be caused by an incorrectly specified set of boundary conditions for p and U. For implicit methods (like the ones used in the above solvers), you need something like
fixed value velocity inlet
zerogradient pressure inlet
zeroGradient velocity outlet
fixedValue pressure outlet
fixedValue (0 0 0) velocity on the walls
zeroGradient pressure on the walls.
these should be stable boundary conditions for laminar pipe flow, assuming your mesh is fine.
jylee4 and piu58 like this.
Old   February 23, 2017, 11:49
Jeremy
Originally Posted by chegdan View Post
Jeremy,
Thank you for the feedback, Dan. I implemented your changes but now I'm playing host to a new cast of problems. The Courant number blows up in just a few iterations and I'm not seeing any flow in Paraview. I adjusted my deltat in the controlDict but I'm not sure what else to do. Any thoughts? I think it could be a scaling issue when I exported from AutoCAD, but the documentation on that whole process is pretty scant.
Old   February 23, 2017, 11:59
Daniel P. Combest
It can be complex, and courant number issues are often resolved with smaller time steps, so you're on the right track. There is a great post
That will make good suggestions on how to get help as sometimes it is difficult to assess the issue with sparse information. A new thread may get more traction.
Old   February 23, 2017, 12:02
Jeremy
Thanks, Dan!
chegdan likes this.
Old   February 13, 2018, 21:36
jiahui_93 is on a distinguished road
Hi, i faced the similar problem but with extra different problems so i started a new post. i am sorry if causing any inconvenience. This is my problem shown
Courant Number mean: 0.04994512 max: 5.830545
Time = 0.005
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#3  Foam::surfaceInterpolation::makeWeights() const at ??:?
#4  Foam::surfaceInterpolation::weights() const at ??:?
#5  Foam::surfaceInterpolation::makeDeltaCoeffs() const at ??:?
#6  Foam::surfaceInterpolation::deltaCoeffs() const at ??:?
#7  Foam::fvPatch::deltaCoeffs() const at ??:?
#8  Foam::mixedFvPatchField<Foam::Vector<double> >::evaluate(Foam::UPstream::commsTypes) at ??:?
#9  Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::Boundary::evaluate() in "/opt/openfoam4/platforms/linux64GccDPInt32Opt/bin/pimpleDyMFoam"
#10  Foam::solidBodyMotionFvMesh::update() at ??:?
#11  ? in "/opt/openfoam4/platforms/linux64GccDPInt32Opt/bin/pimpleDyMFoam"
#12  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#13  ? in "/opt/openfoam4/platforms/linux64GccDPInt32Opt/bin/pimpleDyMFoam"
this is the link to my post
PimpleDyMFoam errors- Foam::error::printStack(Foam::Ostream&) at
I will very appreciate and grateful if there's some advice or suggestion for me to solve this. Thanks a lot for your time
jiahui_93 is offline   Reply With Quote
Savonius pimpleDyMFoam vitokad OpenFOAM Pre-Processing 10 September 16, 2014 10:30
From simpleFoam to pimpleDyMFoam gregjunqua OpenFOAM Running, Solving & CFD 0 May 6, 2014 21:48
pimpleDyMFoam issue giovanidiniz OpenFOAM Running, Solving & CFD 1 July 5, 2013 08:25
pimpleDyMFoam samiam1000 OpenFOAM 2 September 19, 2012 11:11
Error with pimpleDyMFoam samiam1000 OpenFOAM 2 June 11, 2012 07:21
