Unknown patchField type nutSpalartAllmarasWallFunction for patch type wall
hi
I am trying to simpleFoam on an Airfoil design but I keep getting the following error , please help !! --> FOAM FATAL IO ERROR: Unknown patchField type nutSpalartAllmarasWallFunction for patch type wall Valid patchField types are : 104 ( MarshakRadiation MarshakRadiationFixedTemperature advective alphatJayatillekeWallFunction atmBoundaryLayerInletEpsilon calculated codedFixedValue codedMixed compressible::thermalBaffle1D<hConstSolidThermoPhy sics> compressible::thermalBaffle1D<hExponentialSolidThe rmoPhysics> compressible::turbulentHeatFluxTemperature compressible::turbulentTemperatureCoupledBaffleMix ed compressible::turbulentTemperatureRadCoupledMixed cyclic cyclicACMI cyclicAMI cyclicSlip directionMixed empty energyJump energyJumpAMI epsilonLowReWallFunction epsilonWallFunction externalCoupled externalCoupledTemperature externalWallHeatFluxTemperature fWallFunction fan fanPressure fixedEnergy fixedFluxPressure fixedGradient fixedInternalValue fixedJump fixedJumpAMI fixedMean fixedPressureCompressibleDensity fixedUnburntEnthalpy fixedValue freestream freestreamPressure gradientEnergy gradientUnburntEnthalpy greyDiffusiveRadiation greyDiffusiveRadiationViewFactor inletOutlet inletOutletTotalTemperature kLowReWallFunction kqRWallFunction mapped mappedField mappedFixedInternalValue mappedFixedPushedInternalValue mixed mixedEnergy mixedUnburntEnthalpy nonuniformTransformCyclic nutLowReWallFunction nutTabulatedWallFunction nutURoughWallFunction nutUSpaldingWallFunction nutUWallFunction nutkAtmRoughWallFunction nutkRoughWallFunction nutkWallFunction omegaWallFunction oscillatingFixedValue outletInlet outletMappedUniformInlet partialSlip phaseHydrostaticPressure prghPressure processor processorCyclic rotatingTotalPressure sliced slip symmetry symmetryPlane syringePressure timeVaryingMappedFixedValue totalFlowRateAdvectiveDiffusive totalPressure totalTemperature turbulentHeatFluxTemperature turbulentInlet turbulentIntensityKineticEnergyInlet turbulentMixingLengthDissipationRateInlet turbulentMixingLengthFrequencyInlet uniformDensityHydrostaticPressure uniformFixedGradient uniformFixedValue uniformInletOutlet uniformJump uniformJumpAMI uniformTotalPressure v2WallFunction variableHeightFlowRate wallHeatTransfer waveSurfacePressure waveTransmissive wedge wideBandDiffusiveRadiation zeroGradient ) file: /home/salim/task_3_hamid_abedi_rev_1/run/airFoil2D/0/nut.boundaryField.wing from line 49 to line 50. From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&) in file /home/andras/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 143. FOAM exiting |
I have also changed the patchField type to nutUSpaldingWallFunction as it is done in the tutorial but I also got this error message
Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model SpalartAllmaras SpalartAllmarasCoeffs { sigmaNut 0.66666; kappa 0.41; Cb1 0.1355; Cb2 0.622; Cw2 0.3; Cw3 2; Cv1 7.1; Cv2 5; } Employing Ashford correction No finite volume options present SIMPLE: no convergence criteria found. Calculations will run for 2000 steps. Starting time loop forceCoeffs forces: Not including porosity effects Time = 0.5 --> FOAM FATAL IO ERROR: keyword div((nuEff*dev(T(grad(U))))) is undefined in dictionary "/home/salim/task_3_hamid_abedi_rev_1/run/airFoil2D/system/fvSchemes.divSchemes" file: /home/salim/task_3_hamid_abedi_rev_1/run/airFoil2D/system/fvSchemes.divSchemes from line 32 to line 35. From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 437. FOAM exiting |
please help
I am doing now this tutorial for my graduation project: http://www.tfd.chalmers.se/~hani/kur...ort_task_3.pdf and I have this case file so far : http://www.tfd.chalmers.se/~hani/kur...bedi/files.tgz |
Well, the patch boundary doesn't exist, and you have not defined the discretization scheme for the deviatoric velocity gradient tensor. The error uotput it's pretty self-explanatory
Sent from my GT-I8190L using CFD Online Forum mobile app |
Looks like you are using a case from a newer version of OpenFOAM and running it with an older. Look inside system/fvSchemes and you'll see that div((nuEff*dev(T(grad(U))))) is not defined, but something very similar looking likely is.
