Defining different materials in a solid composition
Old   December 17, 2016, 13:21
Default Defining different materials in a solid composition
Yannic E.
jaroz is on a distinguished road
Hello
Maybe this question seems basic, but i couldn't fnd a sufficient answer.
Is it possibe to define different materials for an assembly of parts, e.g. a circuit board (chips, transistors, PVC) for a single mesh region solver (e.g. buoyantBoussinesqSimpleFoam)?
It seems I can only define material properties of the air volume, but not the solids that are surface meshed.
Thanks
jaroz is offline   Reply With Quote
Old   December 19, 2016, 09:59
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
if you are using the buoyant*Foam solvers, then you only model the fluid region. Hence, there is no possibility to add material properties of different solids. If you are really interested what 's going on in the solid's too, you can use the chtMultiRegion*Foam solver. Here you have to define the solid's separately and for each sold you can set different material properties as heat conductivity, heat capacity etc.
There are other ways like, meshing the fluid and solid within one mesh and set for the solids (all cells of the solids) some Darcy law (fvOptions) in order to stop the flow here. In addition you can then use set fields to set different properties but this is not the common way and if you have different small solids, its not the best workflow.
In the foamExtend version there is also a coupledCHT solver but I do not know whats the different.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   November 24, 2024, 02:42
Suhan Umur Okuducu
suoCFD is on a distinguished road
Hi All
Doesnt change anything about this subject since 2016?
suoCFD is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
[CAD formats] Mesh for a solid described by parametric surfaces Align OpenFOAM Meshing & Mesh Conversion 1 August 24, 2016 05:37
defining two kinds of properties for solid zones Rana.P FLUENT 1 September 29, 2014 11:51
error message cuteapathy CFX 14 March 20, 2012 07:45
Defining Solid Zones Not working elmcmaster FLUENT 3 May 22, 2009 08:14
