Home > Forums > OpenFOAM
Floating point exception error !
Like Tree1Likes
  • 1 Post By alexeym
Old   December 17, 2016, 19:23
Default Floating point exception error !
Zack is on a distinguished road
Hi All
I am modifying one of the solvers in v1606+... Compiling the new lines of the code does not show any error... But when I am running the test case, I am facing below error:
Calculating S_X
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so"
#2 ? in "/lib64/libc.so.6"
#3 Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&) in "/opt/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so"
#4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::sqrt<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh>
onst&) in "/home/ofuser/OpenFOAM/ofuser-v1606+/platforms/linux64GccDPInt32Opt/bin/LTCFoam"
#5 ? in "/home/ofuser/OpenFOAM/ofuser-v1606+/platforms/linux64GccDPInt32Opt/bin/LTCFoam"
#6 __libc_start_main in "/lib64/libc.so.6"
#7 ? in "/home/ofuser/OpenFOAM/ofuser-v1606+/platforms/linux64GccDPInt32Opt/bin/LTFoam"
My code lines:
//calculating S_X
Info<< "Calculating S_X \n" << endl;
volScalarField S_X
IOobject
"S_X",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
S_turb*Foam::sqrt(1.+tauTurbPrime/(runTime-tO)*(Foam::exp(-1.*(runTime-tO)/tauTurbPrime)-1.))
I know the problem is coming from dividing by zero but I still can not manage it! Any suggestion ? What is the proper way of using sqrt and exp functions?
Tnx.
Zack
Zack is offline   Reply With Quote
Old   December 18, 2016, 05:43
Alexey Matveichev
alexeym will become famous soon enoughalexeym will become famous soon enough
Send a message via Skype™ to alexeym
No, problem is not division by zero (sigSpe is not necessarily caused by division by zero), it is square root of negative number.
Proper way to use sqrt is to check a sign of its parameter before calling function.
Zack likes this.
alexeym is offline   Reply With Quote
Old   December 18, 2016, 12:09
Hi Alexeym
Thank you. You are right. I did not pay attention to that! mag () after sqrt () solved the issue.
Thread Tools
Trackbacks are On
2 datas on one plot Akuji ParaView 46 December 1, 2013 15:06
Floating point error and divergence detected aannjj FLUENT 0 July 2, 2013 03:44
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Gmsh and samplesurface touf Open Source Meshers: Gmsh, Netgen, CGNS, ... 2 December 10, 2007 03:27
