-   OpenFOAM (https://www.cfd-online.com/Forums/openfoam/)
-   -   locationInMesh keeps bothering (https://www.cfd-online.com/Forums/openfoam/182150-locationinmesh-keeps-bothering.html)
Taghi January 2, 2017 00:59
1 Attachment(s)
Hi.
I am trying to simulate a propeller with pimpleDyMFoam solver with a new geometry and domain. but at running the snappyHexMesh command, after some warnings, the following error appears:
--> FOAM FATAL ERROR:
Point (-0.105003 0.02607 0.06072) is not inside the mesh or on a face or edge.
Bounding box of the mesh:(-0.571 -0.3 -0.300002) (1.989 0.3 0.299998)
From function Foam::labelList Foam::refinementParameters::findCells(const Foam::polyMesh&) const
in file snappyHexMeshDriver/refinementParameters/refinementParameters.C at line 103.
FOAM exiting
as you can see, the point IS in the bounding box and it is not inside the mesh or on a face or edge(I gave it a random coordinate).
please help me out.
Wish you the best times.
Antimony January 3, 2017 04:51
Check your blockMesh. In scenarios similar to the one you have indicated, it is usually the case that the blockMesh is defined inside out as a result of which the point you think should be within, is not within.
Cheers,
Antimony
Taghi January 12, 2017 02:35
it worked
Tnx a lot
