where's the singleGraph output?
I need output for the alpha.water field along a line, to understand I did the singleGraph tutorial: http://cfd.direct/openfoam/user-guid...hs-monitoring/ chapter 6.3.2 It uses the pitzDaily case. So I copied pitzDaily into run, ran blockMesh and simpleFoam on it, made sure it worked with paraView. Then I copied the singleGraph file from FOAM_ETC to system. I edited singleGraph and controlDict as I was told. I ran simpleFoam with and without postProcess option, but I can't find any output in pitzDaily/postProcessing - there's not even a directory called singleGraph. singleGraph Code:
Thanks in advance. |
dunno just did it again
and it worked.
sorry. thread can be closed now, can i do that somewhere? |
