January 5, 2017, 06:49 |
maximum number of faces?
Moritz
Rep Power: 9 |
Hi there,
I already asked this questions in a different thread (https://www.cfd-online.com/Forums/op...faces-shm.html), but I think it's not limited to snappyHexMesh so I post my question here as well. What is the maximum number of faces in openfoam? During meshing I get a negative number of faces: Code:
After refinement gap refinement iteration 1 : cells: 888 490 165 faces: -1 563 835 164 points:952606417 My idea is, that the number of faces is stored as a 32 Bit Integer. So the negative face number has something to do with the 32 Bit Integer Limit, because die number of faces of would be higher in this example. I tried to find something in the source code, but I'm not familiar with it yet, so it's hard for me to find anything. In the snappyHexMesh.C Source code I found where faces are gatherd (line 462) Code:
// Gather all faces List<faceList> gatheredFaces(Pstream::nProcs()); gatheredFaces[Pstream::myProcNo()] = allBoundary.localFaces(); forAll(gatheredFaces[Pstream::myProcNo()], i) { inplaceRenumber(pointToGlobal, gatheredFaces[Pstream::myProcNo()][i]); } Pstream::gatherList(gatheredFaces); Maybe someone who's more familiar with the source code could give me a hint? Thanks for your help! Regards Moritz |
January 5, 2017, 08:53 |
Moritz
Rep Power: 9 |
okay, I figured it out myself. Just in case anybody is interested:
Starting from line 2692 in the meshRefinement.C Source Code (http://cpp.openfoam.org/v4/a07399_source.html) the output for the number of faces is defined. The number of faces is stored in the label "nMasterFaces". With echo $WM_LABEL_SIZE (http://cpp.openfoam.org/v4/a09200_source.html) you can check the size of your labels, 32 or 64 Bit. In my case its 32 Bit, so I assume this is the reason why I get a negative face number and sHM crashed. Depending on your system (if 64Bit is possible or not) you can change the LABEL_SIZE in your bashrc file. Just for completness, the link to my other post where I asked this question: https://www.cfd-online.com/Forums/op...faces-shm.html |
Display Modes | |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 14:49 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
compressible flow in turbocharger | riesotto | OpenFOAM | 50 | May 26, 2014 01:47 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 10:27 |
decomposePar pointfield | flying | OpenFOAM Running, Solving & CFD | 28 | December 30, 2013 15:05 |
