postProcess command
Like Tree1Likes
  • 1 Post By floquation
Old   February 17, 2017, 09:51
Default postProcess command
kens
kensley12 is on a distinguished road
hello there,
I am newbie to OpenFOAM. I am having issue with the cavity tutorials on Openfoam. in the plotting graph section in the tutorial guide, we are asked to use 'postProcess -list' command but it does not work.
http://www.openfoam.com/documentatio...#x4-120001.1.4
section 1.1.5.7
'-bash: postProcess: command not found'
Could anyone please help.. i have no idea what to do. any suggestion plz?
thanks
ken
kensley12 is offline   Reply With Quote
Old   February 17, 2017, 10:01
floquation's Avatar
Kevin van As
floquation will become famous soon enough
What version of OpenFoam are you using? "postProcess" is a rather new functionality.
Are other OpenFoam commands recognised, e.g.:
blockMesh -help
floquation is offline   Reply With Quote
Old   February 17, 2017, 10:13
kens
blockMesh -help
hello,
yes blockMesh works but the postProcess no. Im using an older version of OpenFOAM 1.7.1
I was told to use this as it is part of university pcs. no choice to use newer version unless the IT department install them on the PCs.
thanks
Old   February 17, 2017, 10:22
floquation's Avatar
Kevin van As
Originally Posted by kensley12 View Post
hello,
thanks
Then there you have your answer. Your version does not have that functionality.
So you can either find the old version of that tutorial, or you should consider upgrading.
(I'm hoping OF 1.7.1 is an OF-extend version rather than an OF version, otherwise it is ridiculously old... In that case, I'd consider it non-optional to upgrade. There is no reason to start learning an old version.)
Old   February 17, 2017, 10:30
kens
is there any other way to get the data from Openfoam other than using postProcess command?
any suggestions?
Old   February 17, 2017, 10:56
floquation's Avatar
Kevin van As
You can use paraView (which is also mentioned in the official OF tutorial) to visualise your solution and extract information.
ZW Yang likes this.
Old   November 13, 2024, 22:59
zhengwei yang
ZW Yang is on a distinguished road
My openfoam version is 2.4.x, can it use the command postProcess?
ZW Yang is offline   Reply With Quote
Old   November 14, 2024, 03:35
Yann
Yann will become famous soon enoughYann will become famous soon enough
the postProcess utility has been introduced in OpenFOAM-4.0, it is not available in 2.4.x.
Yann is offline   Reply With Quote
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 11:37
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
