September 21, 2016, 10:50 |
Using power-law equations in driftFluxFoam
Elena Valle
Rep Power: 9 |
Hello
I'm using driftFluxFoam to model a secondary settling tank. I want to use a power-law function, (V0, x and q are constants) Udm_ = (rhoc_/rho())*V0_/(1 + Foam:: pow((alphad_/x_), q_)); but when I start the simulation I get this error p { margin-bottom: 0.25cm; line-height: 120%; }a:link { } 0 Foam::error:: printStack(Foam::Ostream&) at ??:? [5] #1 Foam::sigFpe::sigHandler(int) at ??:? [5] #2 in "/lib/x86_64-linux-gnu/libc.so.6" [5] #3 in "/lib/x86_64-linux-gnu/libm.so.6" [5] #4 pow in "/lib/x86_64-linux-gnu/libm.so.6" [5] #5 Foam:: pow(Foam::Field<double>&, Foam::UList<double> const&, double const&) at ??:? [5] #6 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:: pow<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::dimensioned<double> const&) at ??:? [5] #7 Foam::relativeVelocityModels::diehl::correct() at ??:? [5] #8 [5] at ??:? [5] #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [5] #10 [5] at ??:? [julien-TERRA-PC:05300] *** Process received signal *** [julien-TERRA-PC:05300] Signal: Floating point exception (8) [julien-TERRA-PC:05300] Signal code: (-6) [julien-TERRA-PC:05300] Failing at address: 0x3ea000014b4 [julien-TERRA-PC:05300] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x36d40) [0x7fca49befd40] [julien-TERRA-PC:05300] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x39) [0x7fca49befcc9] [julien-TERRA-PC:05300] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x36d40) [0x7fca49befd40] [julien-TERRA-PC:05300] [ 3] /lib/x86_64-linux-gnu/libm.so.6(+0x15a95) [0x7fca4a1aaa95] [julien-TERRA-PC:05300] [ 4] /lib/x86_64-linux-gnu/libm.so.6(pow+0x1c) [0x7fca4a1bb9ac] [julien-TERRA-PC:05300] [ 5] /opt/openfoam231/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam3powERNS_5FieldIdEERKNS_5UL istIdEERKd+0x42) [0x7fca4aeb0e12] [julien-TERRA-PC:05300] [ 6] /home/elenavalle/OpenFOAM/elenavalle-2.3.1/platforms/linux64GccDPOpt/lib/libdriftFluxRelativeVelocityModels.so(_ZN4Foam3pow INS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14Geom etricFieldIdT_T0_EEEERKS8_RKNS_11dimensionedIdEE+0 x176) [0x7fca4de6a656] [julien-TERRA-PC:05300] [ 7] /home/elenavalle/OpenFOAM/elenavalle-2.3.1/platforms/linux64GccDPOpt/lib/libdriftFluxRelativeVelocityModels.so(_ZN4Foam22re lativeVelocityModels5diehl7correctEv+0x59) [0x7fca4de68db9] [julien-TERRA-PC:05300] [ 8] diehldriftFluxFoam() [0x43bada] [julien-TERRA-PC:05300] [ 9] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7fca49bdaec5] [julien-TERRA-PC:05300] [10] diehldriftFluxFoam() [0x440dbb] [julien-TERRA-PC:05300] *** End of error message *** Seeing some coments, this is a mathematical error because alphad_ turns into negative values (I do not know why). So, can somebody help me, telling me how can I avoid this error? Thank you so much |
March 10, 2017, 11:33 |
Denys Wickens
Rep Power: 9 |
alpha_ routinely goes small and negative in driftFluxFoam. It looks like rounding errors due to the limited precision available in 'double' variables. To overcome this I used a temporary variable thus:
volScalarField X = sqrt(sqr(alpha_)); However, I also note your equation involves rho. Are you sure? As I look at slurry.C, driftFluxFoam uses mu not nu and applies a calculated mixture rho in the code that calls the selected transportModel. |
Carreau-Yasuda, Generalized Power Law and Casson Viscosity Models | Gespenster | FLUENT | 1 | August 25, 2016 02:32 |
Non-Newtonian Power Law for Viscosity | John | FLUENT | 16 | September 12, 2015 06:18 |
Non-Newtonian Generalized Power Law | VPassamai | STAR-CCM+ | 0 | July 24, 2015 10:56 |
UDF for Non-Newtonian power law fluids | Iman Sengupta | Fluent UDF and Scheme Programming | 1 | July 14, 2015 15:20 |
Power law vs fixed coeff porosity models | s1dev | OpenFOAM Running, Solving & CFD | 0 | December 29, 2014 17:52 |
