setFieldDict
Old   March 26, 2012, 03:55
Default setFieldDict
Samuele Z
samiam1000 is on a distinguished road
Dear all,
I have found this dictionary, setFieldDict, and I am finding it very useful.
I have this dictionary for my case:
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      setFieldsDict;
defaultFieldValues
    volScalarFieldValue T 278
regions
    // Set patch values (using ==)
    zoneToCell
        name air_infinite;
        fieldValues
            volScalarFieldValue T 298
What I would like to know is if the temperature in the air_infinite zone will remain constant (T = 298) during the whole simulation.
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   March 26, 2012, 08:20
Disabled
anon_a is on a distinguished road
Well, you will have to do the simulation to check that! :-p
In the general case no, that's just an initial condition.
anon_a is offline   Reply With Quote
Old   March 26, 2012, 08:24
Samuele Z
That's what I did ..
I asked in order to avoid the simulation.. Anyway, do you know how to impse a certain value (let's say temperature) in a volume during the whole simulation??
Old   March 26, 2012, 09:10
Disabled
You can check some previous posts for that:
http://www.cfd-online.com/Forums/ope...-solution.html
http://www.cfd-online.com/Forums/ope...lculation.html
http://www.cfd-online.com/Forums/ope...ll-solver.html
I am afraid that it is not done easily with some tool, you will have to play with the code.
Old   March 26, 2012, 09:17
Samuele Z
Thanks a lot.
Actually, I did it for buoyantSimpleFoam, but I am getting a strange errore with buoyantPimpleFoam.
I'm trying again and again! Hope to solve it!
Thanks again,
Samuele.
Old   March 3, 2017, 01:28
Default setFielddict
sudhakar singh
Sud09463 is on a distinguished road
hello,
I am using following setFieldDict for my case:
| \\ / O peration | Version: 2.1.x |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
defaultFieldValues
volScalarFieldValue alpha1 0
regions
cylinderToCell
p1 (0 0 0);
p2 (0 0 70e-3);
radius 2.285-3;
fieldValues
volVectorFieldValue U (0 0 107)
volScalarFieldValue f 1;
I want to know that what is the meaning of this Dict file? fieldValues that i am assigning will be imposed to which face of the cylinder? whether at face having point P1 or face having point P2?
I am not able to understand this. Can anybody help me?
Sud09463 is offline   Reply With Quote
Old   March 3, 2017, 02:58
floquation's Avatar
Kevin van As
floquation will become famous soon enough
Please use [code]-tags to show code. Otherwise you lose alignment/indentation which makes it nasty to read...
It is volumetric:
All cells within the cylinder with axis \vec{p}_2-\vec{p}_1 (and therefore both its height and position are defined) and radius "radius", are selected. Then the specified values for U and f are applied as initial condition to those cells.
floquation is offline   Reply With Quote
