Home > Forums > OpenFOAM
fvOptions meanvelocityForce to localvelocityforce
Old   March 7, 2017, 07:10
Default fvOptions meanvelocityForce to localvelocityforce
hxaxtma is on a distinguished road
Hi guys,
did someone of you tried to rewrite the meanVelocityForce fvOptions files to a localVelocityForce one?
Which means I want to model a non-slip wall by imposing velocity to (0 0 0) with respect to local velocity distribution at each cell of the cellset.
So far I managed to rewrite the code successfully up to here:
void Foam::fv::localVelocityForce::addSup
    fvMatrix<vector>& eqn,
    const label fieldI
	scalar gradP = gradP0_ + dGradP_;
	scalarField gradPlocal_ = gradP0_ + dGradPlocal_;
	DimensionedField<vector, volMesh> SuI
        IOobject
            name_ + fieldNames_[fieldI] + "_SuI",
            mesh_.time().timeName(),
            mesh_,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        mesh_,
        dimensionedVector("zero", eqn.dimensions()/dimVolume, vector::zero)
    forAll(cells_, i)
		label cellI = cells_[i];
		SuI[cellI] += flowDir_*gradPlocal_[cellI];
		UIndirectList<vector>(SuI,cells_) = flowDir_*gradPlocal_; ->This line is the problem!!!!
    eqn += SuI;
The problem is caused by gradPlocal_ which is a scalarField multiplied by flowDir_ equals in a volVectorField.
So my question is, how can I use UIndirectList as a volVectorField.
Or is there a way to impose Sui as volVectorField directly within the last line eqn +=SuI?
Thanks in advance
hxaxtma is offline   Reply With Quote
Old   March 8, 2017, 19:39
no one has an idea?
Thread Tools
Trackbacks are On
fvOptions MRF error vijaykamesh OpenFOAM 1 July 28, 2016 09:37
fvOptions with twoPhaseEulerFoam: momentumSource tidusuper91 OpenFOAM Pre-Processing 2 March 21, 2016 06:39
How to set fvOptions yurifrey OpenFOAM Pre-Processing 5 February 22, 2016 19:14
problem with fvOptions in twophase eulerfoam Hamzeh_Mirab OpenFOAM Running, Solving & CFD 0 January 27, 2015 12:04
Can I use fvOptions to couple a solid region and a fluid region? titanchao OpenFOAM Running, Solving & CFD 0 July 24, 2014 13:36
