March 7, 2017, 06:03 |
C++ explanation of dynamicMeshDict file
Emre
Rep Power: 10 |
I wonder how to reach and use the velocity number in another file, e.g., own custom solver? I mean I'm a bit confused about using scope :: symbol due to lack of understanding the complex class and object definitions and their relations to each other in OpenFOAM. Here is the dynamicMeshDict file that contains velocity and translation function: Code:
FoamFile { version 2.0; format ascii; class dictionary; object dynamicMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dynamicFvMesh immersedBoundarySolidBodyMotionFvMesh; immersedBoundarySolidBodyMotionFvMeshCoeffs { motionFunctions ( IB_block { solidBodyMotionFunction translation; translationCoeffs { velocity (2 0 0); rampTime 0.5; } } ); }
March 11, 2017, 02:03 |
Fatih Ertinaz
Rep Power: 15 |
Hi
It seems that you're in a confusion between the source code behind the dictionary file and the content of the dictionary file you shared. dynamicFvMesh is the type of the mesh motion supported by OpenFoam library. If you wanna see its core implementation you can check: $FOAM_SRC/dynamicFvMesh/ When you do an ls -l here, you will see
which are exactly the types you will find in the tutorial cases. You can see them running the command grep -rn "dynamicFvMesh" */* I guess the type that you're working on belongs to a different version of OF (I switched to 4.x recently) so I do not know the details of your specific example however you can probably find its details by looking at the source code. Just beware that dynamicFvMesh was in $FOAM_SRC/dynamicMesh/ directory in previous versions. You can find its location using grep. Mesh motion is invoked by the dynamicFvMesh type, therefore you can find how the coefficients are read and how they are evaluated in the source code. But again the file you shared is not a c++ class file, it is a dictionary file designed for I/O file operations in OpenFoam. Hope this helps // Fatih |
March 12, 2017, 09:31 |
Emre
Rep Power: 10 |
Thank you for your reply. This belongs to foam-extend 3.2.
c++, dynamicmeshdict, dynamicmeshfvmesh, foam extend 3.2, immersed boundary method |
Display Modes | |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 04:23 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 12:44 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 18:18 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
