Home > Forums > OpenFOAM
Matching OpenFOAM to ANSYS CFX results
Old   March 17, 2017, 10:51
Default Matching OpenFOAM to ANSYS CFX results
Audrius
driu is on a distinguished road
Hello Everyone,
Recently started learning OpenFOAM. I am trying to define the inlet turbulence exactly how I have it in ANSYS CFX.
In CFX I have used Medium, which means 5% intensity and a viscosity ratio μ_t/μ equal to 10.
In OpenFOAM I have used Intensity and Length Scale:
For k
inlet
type turbulentIntensityKineticEnergyInlet;
intensity 0.05;
value $internalField;
For omega
inlet
type turbulentMixingLengthFrequencyInlet;
mixingLength 0.021; //0.07 x Hydraulic Diameter
It's kOmegaSST turbulence model BTW.
I know the problem is in the k and omega specification because if I specify them as fixed values, OpenFOAM and CFX give identical results.
So my questions are:
1) Is it possible in OpenFOAM to specify the intensity and the viscosity ratio instead of length scale?
2) If not, can I calculate turbulent length scale from the viscosity ratio?
3) Maybe I should'n stick to the CFX's default turbulence setting and there is a better way of estimating the turbulence values for the inlet?
Many thanks,
Audrius
driu is offline   Reply With Quote
Thread Tools
Trackbacks are On
The ANSYS CFX solver exited with return code 1. No results file has been created moodkiller CFX 7 May 23, 2016 02:16
Ansys CFX to VTK - Postprocessing results sorrego CFX 10 October 16, 2015 10:48
I got code 1 error from ANSYS CFX zlor1324 CFX 0 March 11, 2014 20:22
Velocity spots in openFoam results Valle OpenFOAM Running, Solving & CFD 4 August 19, 2009 05:53
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 02:10
