April 12, 2017, 11:40 |
BubbleInterTrackFoam Wedge Problem
Manuel
Rep Power: 13 |
Dear All,
I am trying to use bubbleInterTrackFoam with a wedge geometry in foam-extend 3.1. After few time steps the solver blows up. Any hints?? Thanks Manuel |
April 18, 2017, 04:30 |
Manuel
Rep Power: 13 |
Some more details...
I have duplicated the points on the axis and I have created small faces out of them. These faces belong to a "symmetryPlane" patch called "centerline". First I tried to create a standard wedge geometry with zero faces along the axis but in this case the mesh motion did not work at all. Having a look at the freeSurface class then I have figured out that a patch "centerline" along the axis is required by the solver for a correct mesh motion. Despite this correction, the solver blows up immediately. At the moment I have no idea about what causes the problem. I have attached the case. Run the script "meshCreation" in order to create the fvMesh and faMesh. Has anyone ever performed a wedge simulation with bubbleInterTrackFoam?? I am waiting for your comments and suggestions. Thanks. Manuel |
April 20, 2017, 21:53 |
Rep Power: 9 |
A few things that could help, but I'm not sure
1.) Have you tried bringing your foam-extend to version 4.0:https://sourceforge.net/p/foam-exten...i/master/tree/ But I just confirmed that in foam-extend-4.0 your case also runs only a few time steps until it crashes... 2.) Try to turn your wedge mesh into an annulus with a tiny whole along the central axis and apply a symmetray plane there 3.) Use a fvMotionSolver instead of the tetFemMotionSolver, as the latter might still have problems with the axis 4.) Try to decrease the time step and adjust all schemes 5.) Something seems to be wrong with the inletOutlet boundary condtion of U at the space patches, as the velocity field gets weird there. You should re-check this. Maybe there is a nasty bug in bubbleInterTrackFoam for wedgeMeshes... 6.) Have you tested the tutorials with bubbleInterTrackFoam? Do they run properly? |
April 26, 2017, 06:44 |
Manuel
Rep Power: 13 |
Hi p.b.,
Sorry for the late answer but due to other tasks I could not try your suggestions immediately. Regarding the geometry I was already using along the central axis a tiny patch with symmetryPlane conditions instead of a line. Maybe I did not explain it well in my previous post. I switched from the tetFemMotionSolver to the fvMotionSolver. It helps slightly and makes the computation faster but it does not solve the problem. Looking more deeply at the code, I have noticed that the bubble center is not correctly computed in the solver in the case of wedge geometry because it does not consider that the domain is only a slice of the "real" bubble. For this reason I have changed the file createBubble.H and updateMovingReferenceFrame.H imposing Cb.x() =0. In addition to this, I have found out that in the updateVelocity() of the freeSurface class the term tangentialSurfaceTensionForce causes some troubles at the top of the bubble. Since in my simulations I have no gradient of the surface tension coefficient I have commented out this term for the moment. With these two changes the simulation runs longer but slightly before 1ms it crashes again. Looking at the p and U fields in Paraview they seem fine apart the z component of the velocity which continuously raises during the simulation. I attach the pictures of the fields at a time instance close to the crash. Do you have any suggestions about it? Thanks Manuel |
April 27, 2017, 10:21 |
Rep Power: 9 |
Sorry, but I have no more ideas. The tangential surface tension term made also problems in some of my simulations with interTrackFoam. I could also not run any cases with wedge-meshes for too small axis-patches (maybe try a "larger whole" in the centre of the bubble, just to see if this has any influence). To me it looks like there lurks a nasty bug in the freeSurface library (and there are for sure some!) or the moving reference frame calculations. It could also be related to the calculation/scaling of phi.
I'd suggest you to contact Zeljko Tukovic (the author of bubbleInterTrackFoam) from the University of Zagreb (Croatia) with a friendly mail, directly! :-) Another option would be to contact Holger Marschall from the University of Darmstadt (Germany). They both are great experts in the field. If you have any update on this, please let me know, as I'm very curious how to fix this problem! |
April 27, 2017, 10:33 |
Rep Power: 9 |
There is one more!
Try to define the axis patch as general patch (not as symmetryPlane) and use slip boundary conditions for all fields! There maybe some boundary cases missing in the freeSurface library or the calculations for bubbleInterTrackFoam. For the tetPointVectorField, slip seems to be broken, too. So either stick with fvMotionSolver for this test or use the componentMixed boundary condition for motionU at the axis: Code:
axis { // type slip; // broken in combination with wedge? type componentMixed; refValue uniform (0 0 0); valueFraction uniform (1 0 0); // axis direction should be one! } |
April 27, 2017, 10:48 |
Rep Power: 9 |
Have you also tried killing the y-component of U in the solver, e.g. by
U.replace(2, ZERO_VOL_SCALARFIELD); |
April 28, 2017, 06:04 |
Manuel
Rep Power: 13 |
Hi p.b.,
I have tried all your suggestions but the simulation still crashes. Also forcing the z component of the velocity to zero doesn't help because the problem is transferred to the other components. I work in Darmstadt in the Holger Marschall's group. So if he had a solution it would be easy for me to contact him . I will try to send an email to Zeljko Tukovic. If I have any update, I will let you know. Thanks for your help!! Manuel |
bubbleintertrackfoam, interface tracking, wedge |
[blockMesh] Wedge shape meshing problem! | aydemirk | OpenFOAM Meshing & Mesh Conversion | 3 | August 20, 2014 10:50 |
Wedge water impact DFBI Overset mesh | jcamilleri | STAR-CCM+ | 1 | March 31, 2014 12:58 |
Wedge Impact Problem | Vimal | FLUENT | 0 | September 24, 2007 17:21 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
