April 19, 2017, 10:41 |
courant number initially very high
Ashok
Rep Power: 9 |
Once at the very beginning of simulation only for first 2 iterations courant number is very very high, after that in the next iterations less than 1 till the end of simulation. Does this high value of courant number at very beginning affect my results severely ? Thanks, Ashok.M |
April 20, 2017, 20:53 |
Rep Power: 9 |
This totally depends on the type of your simulation (steady/unsteady), boundary conditions, initial field values, ...
For steady simulations, only the result at the end (the converged solution) is important. For unsteady simulations the Courant number only makes sense if your velocity is not completely zero at the beginning of the simulation, as then your time step size might be way to large. There it might help to limit your time step initially with maxDeltaT in controlDict. Please try to briefly describe your test case and your simulation and I will try to give you a better answer. Best, Pascal |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 09:23 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
