Error in reconstructPar using externalCoupled BC
Old   May 3, 2017, 02:31
Default Error in reconstructPar using externalCoupled BC
PHabib is on a distinguished road
Hello everyone,
I'm getting an error using reconstructPar. The decomposing works without problems, but reconstructing the volVectorField U leads to an error. I am using OF 2.3 and the Boundary condition "externalCoupled" for U.
Does anyone now how to handle this error? any help will be much appreciated.
Here is the error output:
command:
reconstructPar -fields '(U)'
Create time
Reconstructing fields for mesh region0
Time = 0.0001
Reconstructing FV fields
    Reconstructing volScalarFields
    Reconstructing volVectorFields
        U
externalCoupled: removing lock file
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigSegv::sigHandler(int) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::externalCoupledMixedFvPatchField<Foam::Vector<double> >::baseDir() const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#4  Foam::externalCoupledMixedFvPatchField<Foam::Vector<double> >::removeLockFile() const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#5  Foam::externalCoupledMixedFvPatchField<Foam::Vector<double> >::~externalCoupledMixedFvPatchField() in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#6  Foam::externalCoupledMixedFvPatchField<Foam::Vector<double> >::~externalCoupledMixedFvPatchField() in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/reconstructPar"
#11  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#12
Segmentation fault (core dumped)
PHabib is offline   Reply With Quote
Old   April 25, 2019, 11:07
Dozer_94 is on a distinguished road
Hi there,
I'm sorry, I don't have an answer to your problem. I am interested however in how you wrote your data input file for the externalCoupled boundary condition for the velocity.
I know that for a scalar field like Temperature it should look like this:
<value1> <gradient1> <valueFraction1>
Could you show me what format is to be used for a vector field like Velocity? I have had no luck digging through the source code...
Dozer_94 is offline   Reply With Quote
Old   May 7, 2019, 03:59
Gerry Kan's Avatar
Gerry Kan
Gerry Kan is on a distinguished road
Dozer:
Here is the supposed format for externalCoupled for velocities, also by PHabib (response #4).
VectorSpace cmpt
Hope this helps, Gerry.
Gerry Kan is offline   Reply With Quote
Old   May 7, 2019, 04:28
Gerry,
Great, thanks! Don't know why I couldn't find this thread.
Old   August 22, 2019, 03:23
Gerry Kan's Avatar
Gerry Kan
Hallo PHabib:
I don't know if you have solved the problem already. I encountered the same problem with externalCoupled as well.
Upon looking into the offending function
template<class Type>
Foam::externalCoupledMixedFvPatchField<Type>::
{    removeLockFile();    }
and the corresponding function it calls
void Foam::externalCoupledMixedFvPatchField<Type>::removeLockFile() const
    if (!master_ || !Pstream::master())
    {    return;    }
    if (log_)
    {    Info<< type() << ": removing lock file" << endl;    }
    rm(lockFile());
I realize it is asking the head node to remove the lock file.
In my case I modified the the externalCoupled BC so that the lock file never gets created, and the same error you had with reconstructPar appeared. The call to removeLockFile() was then commented out from the destructor and reconstructPar worked fine again.
It could be that the file OpenFOAM.lock was removed between the end of your run and calling reconstructPar. If this is true, the solution would either be preventing this file from being erased, or recreating it prior to calling reconstructPar.
Let me know if you have solved your problem, and how, if your solution is different.
Gerry.
error, externalcoupled, reconstructpar
externalCoupled BC/function object without patch jbcourt OpenFOAM Running, Solving & CFD 0 March 30, 2017 05:29
reconstructPar does not work in interDyMFoam ageorg OpenFOAM Post-Processing 4 April 15, 2016 13:25
reconstructPar nor working Priya Somasundaran OpenFOAM Post-Processing 2 January 28, 2016 14:37
reconstructPar and a high number of snapshots fs82 OpenFOAM Programming & Development 2 April 18, 2012 04:37
Problem with reconstructPar fabianpk OpenFOAM 5 August 14, 2007 09:17
