August 9, 2017, 08:59 |
patch mass flows in 1706
Rep Power: 17 |
Hello all,
I am evaluating 1706 compared to previous versions, and one very large annoyance is the persistent difficulty in getting proper mass flows. In the case of faceZone mass flow rates, I can use the fluxSummary function object, but this STILL lacks the "phi flip" functionality of swak4foam and thus gives rubbish values, since faceZones are not oriented. For patches however, I can't get a flow rate at all. The "flowRatePatch" function from the OpenFOAM.org release is non existent, and fluxSummary works for surfaces, faceZones, and cellZones. Source: http://www.openfoam.com/documentatio...y.html#details Does anyone know, if there a way to get patch mass flows in 1706? |
August 9, 2017, 12:26 |
Philippose Rajan
Rep Power: 25 |
Hi there,
Why not just use swak4Foam? I personally find the swak4Foam interface to be much more consistent across multiple OpenFOAM versions anyway. Regards, Philippose |
August 10, 2017, 08:53 |
Rep Power: 17 |
I will try that as well, haven't tested if it work with 1706. But in general I would like to use the standard distro as much as possible. There have been mass flow calculators in the past, so there's gotta be one in this 1706.
August 10, 2017, 09:40 |
Anton Kidess
Rep Power: 29 |
You seem to already know how to sample on a faceZone. You can create a faceZone from you patch via topoSet. Or you directly use a faceSource functionObject:
https://github.com/OpenFOAM/OpenFOAM...e/faceSource.H
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
August 10, 2017, 09:41 |
#5 | |
Rep Power: 17 |
August 10, 2017, 11:39 |
Anton Kidess
Rep Power: 29 |
Right. 1706 has surfaceFieldValue.
surfaceFieldValue1 { type surfaceFieldValue; libs ("libfieldFunctionObjects.so"); log true; writeControl writeTime; writeFields true; regionType patch; name YOUR_PATCH; operation sum; fields (phi); }
August 10, 2017, 13:13 |
Rep Power: 17 |
So that's where it went! Brilliant, thanks a lot :-)
August 11, 2017, 01:56 |
Anton Kidess
Rep Power: 29 |
Which versions did you compare to? AFAIK that's how it's always been and newer CFD-direct versions work differently (since introducing the postProcess tool).
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
