OpenFOAM
Greetings,
I am a new OpenFOAM user, using OpenFOAM 2.4.0, When I try to execute the command fluentMeshToFoam elbow.msh, i get feedback that command not found. How can I rectify this? Also, everytime I open a new terminal, there's "bash: /home/tflows/ .bashrc: line 119: syntax error: unexpected end of file" What does it mean and how can I rectify it? Thank you PATRICIA |
Hi Patricia,
the problem is that you FOAM environment is not setup correctly. Therefore I think you installed FOAM and not compiled it. Therefore you have to load the bashrc from the /opt/openfoam.../etc/bashrc into your shell. However, you problem is not related to openfoam directly. It is more Linux/Unix stuff. The error you got if you open a terminal let you know that you made some mistakes in you local .bashrc. Open it and resolve the problem and put the correct path to the openfoam environment. To make things clear: Code:
cd $HOME Code:
echo "alias fo240=\"/opt/OpenFOAM-2.4.0/etc/bashrc\" >> $HOME/.bashrc Code:
fo240 Code:
checkMesh |
