-   OpenFOAM (https://www.cfd-online.com/Forums/openfoam/)
-   -   velocity profile mixing hot and cold water in a pipe (https://www.cfd-online.com/Forums/openfoam/188366-velocity-profile-mixing-hot-cold-water-pipe.html)
ari92 May 28, 2017 14:26
1 Attachment(s)
Hello everybody,
I would like to simulate a pipe flow with two inflows ( first inflow cold 10 ; second inflow 54C) and one outflow with the mixture of both (at 37C).
I'm using icoFoam solver modified to solve temperature equation.
The inlet where I have hot water, which enter at a velocity of 0.026 m/s, is inclined at an angle of 70.
I have problem with the velocity profile it is not working well, while for the temperature i got a good result.
this is the 0/U file:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inletFace1
type fixedValue;
value uniform (0.00644 0 0);
inletFace2
type fixedValue;
value uniform (0.00699 -0.01922 0);
outletFace
type zeroGradient;
lowerWall
type fixedValue;
value uniform (0 0 0);
upperWall
type fixedValue;
lateralWall
type fixedValue;
frontAndBack
type empty;
I can't find the error...
thank you very much
nsf June 1, 2017 16:11
Hi arianna,
I think you got the velocity on inletFace2 wrong. O think the magnitude is approximately 0.021 m/s. There is a surfaceNormal boundary condition that might be easier to use.
Best Regards
Nicolas
