Extremely Small Time step to Maintain Courant Number of 10
I am running a komegasst simulation in parallel containing 4 million elements. I made my mesh using ansys meshing software and below is the checkMesh results:
Mesh stats points: 2076394 internal points: 1949842 faces: 12198649 internal faces: 11945553 cells: 5177068 faces per cell: 4.66368 boundary patches: 4 point zones: 0 face zones: 1 cell zones: 1 Overall number of cells of each type: hexahedra: 0 prisms: 3435930 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 1741138 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 2238 1186 ok (non-closed singly connected) outlet 2238 1186 ok (non-closed singly connected) wall 19558 9911 ok (non-closed singly connected) cube 229062 114533 ok (closed singly connected) Checking geometry... Overall domain bounding box (-1.09 -1.01797 -2.75) (1.09 1.0272 1.75) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-3.05175e-16 6.10809e-16 -3.99538e-17) OK. Max cell openness = 6.63526e-16 OK. Max aspect ratio = 20.153 OK. Minimum face area = 3.21818e-08. Maximum face area = 0.0145499. Face area magnitudes OK. Min volume = 1.00001e-11. Max volume = 0.000502156. Total volume = 20.0617. Cell volumes OK. Mesh non-orthogonality Max: 62.8113 average: 12.8053 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.47308 OK. Coupled point location match (average 0) OK. Mesh OK. End In controlDict I specified that I need a courant number below 10 and openFoam corrects it. Except to have a courant number of 10, my time steps are around 1e-53 and then the last one is 1e-108 and the program throws a floating point error. If someone minds taking a look that would be great. Thanks! I can upload my files to if needed. |
Why are you going for 10?
Your simulation is probably just diverging, with velocities over 1e50. Then, the dynamic Courant criterion demands that your timestep is less than 1e-53 (of course, depending on your cell sizes). Try maxCo=0.5, and see what happens. Co>1 is unstable. The only way to perform those kind of simulations is with heavy under-relaxation and possibly some other tricks. |
Which solver are you using? Do you use underrelaxation?
I am using pimple foam and my underelaxation values are .7 on U and .3 on everything else.
Hello Everyone!
My calculation is converging evey time, and my courant number are as follows: Global Courant Number [Variable Time Step Criteria] : 0.07 Global Courant Number [Explicit VOF Criteria] : 0.01 I am running my simulation on HPC cluster. Are those value good to have a flow ?? Thank you in advance! |
