simpleGrading giving error
Old   June 7, 2017, 13:11
Default simpleGrading giving error
Ashok
ashokmoravaneni is on a distinguished road
Hello everyone,
I have created a cylinder using blockMesh and it seems OK when simpleGrading is (1 1 1). Actually I need refinement at the edges, so i applied simpleGrading of (0.5 1 0.5) which results in an error
"--> FOAM FATAL ERROR:
Inconsistent point locations between block pair 0 and 1
probably due to inconsistent grading."
The complete blockMesh dict is as below,
convertToMeters 1.0;
vertices
(0.033 0 0.033)//0
(0.093 0 0.033)//1
(0.093 0 0.093)//2
(0.033 0 0.093)//3
(0.01845 0 0.01845)//4
(0.10755 0 0.01845)//5
(0.10755 0 0.10755)//6
(0.01845 0 0.10755)//7
(0.033 0.5 0.033)//8
(0.093 0.5 0.033)//9
(0.093 0.5 0.093)//10
(0.033 0.5 0.093)//11
(0.01845 0.5 0.01845)//12
(0.10755 0.5 0.01845)//13
(0.10755 0.5 0.10755)//14
(0.01845 0.5 0.10755)//15
blocks
hex (12 15 7 4 8 11 3 0) (15 60 15) simpleGrading (1 1 0.5)
hex (8 11 3 0 9 10 2 1) (15 60 15) simpleGrading (1 1 1)
hex (9 10 2 1 13 14 6 5) (15 60 15) simpleGrading (1 1 0.5)
hex (11 15 7 3 10 14 6 2) (15 60 15) simpleGrading (0.5 1 1)
hex (12 8 0 4 13 9 1 5) (15 60 15) simpleGrading (0.5 1 1)
edges
arc 4 5 (0.063 0 0)
arc 5 6 (0.126 0 0.063)
arc 6 7 (0.063 0 0.126)
arc 7 4 (0 0 0.063)
arc 12 13 (0.063 0.5 0)
arc 13 14 (0.126 0.5 0.063)
arc 14 15 (0.063 0.5 0.126)
arc 15 12 (0 0.5 0.063)
boundary
movingWall
type wall;
faces
(5 6 14 13)
(6 7 15 14)
(7 4 12 15)
(4 5 13 12)
atmosphere
type wall;
faces
(12 13 9 8)
(13 14 10 9)
(14 15 11 10)
(15 12 8 11)
(8 9 10 11)
bottomWall
type wall;
faces
(0 3 2 1)
(4 0 1 5)
(4 7 3 0)
(7 6 2 3)
(6 5 1 2)
mergePatchPairs
Can anyone help me to successfully apply simpleGrading to my Cylinderical domain ?
Thank you.
ashokmoravaneni is offline   Reply With Quote
Old   June 7, 2017, 14:39
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
You have to set the grading for neighboring blocks in an equal way:
hex (12 15 7 4 8 11 **3 0**) (15 60 15) simpleGrading (1 1 0.5)
hex (8 11 **3 0** 9 10 2 1) (15 60 15) simpleGrading (1 1 1)
The first 3-0 section has a grading, the second not. The internal nodes do not fit. That may be not the only mistake, it is the one I saw at the first glance.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   June 7, 2017, 15:03
Ashok
Hello Pilz,
Firstly Thanks for your Answer. After your suggestion I have tried grading as below,
blocks
hex (12 15 7 4 8 11 3 0) (15 60 15) simpleGrading (0.5 1 0.5)
hex (8 11 3 0 9 10 2 1) (15 60 15) simpleGrading (0.5 1 0.5)
hex (9 10 2 1 13 14 6 5) (15 60 15) simpleGrading (0.5 1 0.5)
hex (11 15 7 3 10 14 6 2) (15 60 15) simpleGrading (0.5 1 0.5)
hex (12 8 0 4 13 9 1 5) (15 60 15) simpleGrading (0.5 1 0.5)
But still the same error follows. Can you please check if orientation of blocks is in correct order or not ?
Thank you.
Old   June 7, 2017, 23:59
piu58's Avatar
Uwe Pilz
I recommend making a sketch of your block. You'll what fits and what not.
Uwe Pilz
Old   June 8, 2017, 06:59
Ashok
Thank you. I solved the problem.
Thread Tools
Trackbacks are On
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 07:11
compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 2 August 30, 2013 07:42
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 20:30
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
