Selection of solver
Old   June 23, 2017, 03:18
Default Selection of solver
nsreddy
nsreddysrsit is on a distinguished road
I wanted to simulate the fluid flow and heat transfer through double pipe heat exchanger. Hot water is flowing through the inner tube and cold water flowing through annulus.
Bc are as follows
Hot water inlet temp is 65 C and cold inlet temp is 30 C , mc is 0.1 kg per s and mh is 0.1 kg per sec . Pressure outlet for both the fluids. Please suggest me the appropriate solver for the above problem. Regards
NSReddy
nsreddysrsit is offline   Reply With Quote
Old   June 24, 2017, 22:07
Default books on conjugate heat transfer
nsreddy
Any reference books on conjugate heat transfer to understand algorithms used in openFoam
Thanks and Regards
Population Balance Modeling (PBM) - Ansys Fluent chittipo FLUENT 164 November 18, 2023 11:54
Solver selection for transonic compressor stage in Foam-extend-3.0 dowlee OpenFOAM Running, Solving & CFD 1 April 16, 2015 13:33
Problem in3D model processing mebinitap OpenFOAM 2 December 12, 2014 04:40
3d vof Smaras FLUENT 2 February 19, 2013 06:58
Setting a B.C using UserFortran in 4.3 tokai CFX 10 July 17, 2001 16:25
