Selection of solver
I wanted to simulate the fluid flow and heat transfer through double pipe heat exchanger. Hot water is flowing through the inner tube and cold water flowing through annulus.
Bc are as follows Hot water inlet temp is 65 C and cold inlet temp is 30 C , mc is 0.1 kg per s and mh is 0.1 kg per sec . Pressure outlet for both the fluids. Please suggest me the appropriate solver for the above problem. Regards NSReddy |
books on conjugate heat transfer
Any reference books on conjugate heat transfer to understand algorithms used in openFoam
Thanks and Regards |
