snappyHexMesh is not removing unwanted blockMesh |
January 31, 2020, 03:24 |
Sujith Stephen
Hi i'm Sujith,
I was trying to mesh an STL surface which has open ends(non watertight) using snappyHexMesh. And i found that it is not removing the unwanted parts of blockmesh. i have located the mesh point exactly inside the surface. Please help me.. see the attachment of geometry. |
January 31, 2020, 16:39 |
Herpes Free Engineer
Rep Power: 12 |
I think you should ensure `water-tightness` of your surface mesh to enable snappy acting properly.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
blockmesh, non-watertight, snappyhexmesh 3d |
[blockMesh] blockMesh | MergePatchPairs | snappyHexMesh |Different number of cells in divisions | pythag0ra5 | OpenFOAM Meshing & Mesh Conversion | 1 | September 19, 2020 14:38 |
snappyHexMesh not removing desired portion of blockMesh | siefer92 | OpenFOAM | 2 | July 18, 2019 14:26 |
[snappyHexMesh] Cylindrical blockmesh to Improve snappyHexMesh Results | nicholas.jones | OpenFOAM Meshing & Mesh Conversion | 3 | May 16, 2019 09:52 |
[Gmsh] gMsh instead of blockMesh for base mesh, then snappyHexMesh | sazabi2001 | OpenFOAM Meshing & Mesh Conversion | 0 | February 23, 2017 12:00 |
[snappyHexMesh] snappyHexMesh on a multiple region blockMesh | blais.bruno | OpenFOAM Meshing & Mesh Conversion | 1 | February 17, 2015 05:40 |
