chpjz0391 |
September 12, 2017 09:26 |
Originally Posted by kinbean
(Post 656621)
Hi this is no longer a problem, I now am stuck with something else. The simulation runs then gives up after roughly the third timestep.
It didn't let me upload the full case folder. Nothing has changed in constants from last post.
Does anyone have any ideas?
Thank you for your help
Here is the log.DPM file
Solving 3-D cloud kinematicCloud
Cloud: kinematicCloud injector: model1
Added 101 new parcels
389 move-collide subCycles
tail: unrecognised file system type 0x53464846 for ‘log.DPMFoam’. please report this to bug-coreutils@gnu.org. reverting to polling
Current number of parcels = 101
Current mass in system = 1.6698e-06
Linear momentum = (3.28532e-05 0 -1.26026e-10)
|Linear momentum| = 3.28532e-05
Linear kinetic energy = 0.000323193
model1:
number of parcels added = 101
mass introduced = 1.6698e-06
Parcel fate (number, mass) : patch inlet
- escape = 0, 0
- stick = 0, 0
Parcel fate (number, mass) : patch outlet
- escape = 0, 0
- stick = 0, 0
Parcel fate (number, mass) : patch lowerWall
- escape = 0, 0
- stick = 0, 0
Parcel fate (number, mass) : patch upperWall
- escape = 0, 0
- stick = 0, 0
Parcel fate (number, mass) : patch frontAndBack
- escape = 0, 0
- stick = 0, 0
Parcel fate (number, mass) : patch pipeScale
- escape = 0, 0
- stick = 0, 0
Rotational kinetic energy = 0
PIMPLE: iteration 1
smoothSolver: Solving for U.airx, Initial residual = 1, Final residual = 8.43751e-06, No Iterations 4
smoothSolver: Solving for U.airy, Initial residual = 1, Final residual = 7.63784e-06, No Iterations 4
smoothSolver: Solving for U.airz, Initial residual = 1, Final residual = 3.05085e-06, No Iterations 2
GAMG: Solving for p, Initial residual = 1, Final residual = 0.00525976, No Iterations 6
time step continuity errors : sum local = 7.83773e-09, global = -4.49241e-09, cumulative = -4.49241e-09
GAMG: Solving for p, Initial residual = 0.337878, Final residual = 9.23512e-07, No Iterations 55
time step continuity errors : sum local = 5.76991e-12, global = 4.81013e-12, cumulative = -4.4876e-09
No finite volume options present
smoothSolver: Solving for epsilon.air, Initial residual = 1.03029e-05, Final residual = 1.63543e-07, No Iterations 1
bounding epsilon.air, min: -3.34167 max: 1288.46 average: 39.2906
smoothSolver: Solving for k.air, Initial residual = 1, Final residual = 6.73817e-06, No Iterations 7
ExecutionTime = 12.28 s ClockTime = 13 s
Courant Number mean: 0.000964355 max: 0.40604
Time = 4e-05
Evolving kinematicCloud
407 move-collide subCycles
Linear momentum = (9.46156e-06 -8.20201e-08 -3.47299e-07)
|Linear momentum| = 9.46829e-06
Linear kinetic energy = 3.65316e-05
model1:
- escape = 0, 0
- stick = 0, 0
- escape = 0, 0
- stick = 0, 0
- escape = 0, 0
- stick = 0, 0
- escape = 0, 0
- stick = 0, 0
- escape = 0, 0
- stick = 0, 0
- escape = 0, 0
- stick = 0, 0
PIMPLE: iteration 1
smoothSolver: Solving for U.airx, Initial residual = 0.000491792, Final residual = 4.08364e-06, No Iterations 1
smoothSolver: Solving for U.airy, Initial residual = 0.0346797, Final residual = 6.23164e-06, No Iterations 5
smoothSolver: Solving for U.airz, Initial residual = 0.195751, Final residual = 9.58755e-06, No Iterations 2
GAMG: Solving for p, Initial residual = 0.218458, Final residual = 0.0020271, No Iterations 5
time step continuity errors : sum local = 1.47353e-08, global = -1.97603e-09, cumulative = -6.46363e-09
GAMG: Solving for p, Initial residual = 0.62654, Final residual = 8.9094e-07, No Iterations 60
time step continuity errors : sum local = 2.99806e-12, global = -2.50408e-12, cumulative = -6.46613e-09
smoothSolver: Solving for epsilon.air, Initial residual = 5.98403e-05, Final residual = 1.47682e-06, No Iterations 1
bounding epsilon.air, min: -27110.7 max: 3.65652e+06 average: 32024.8
smoothSolver: Solving for k.air, Initial residual = 0.00025891, Final residual = 7.1125e-06, No Iterations 6
ExecutionTime = 17.75 s ClockTime = 18 s
Courant Number mean: 0.000964269 max: 0.385256
Time = 6e-05
362 move-collide subCycles
Linear momentum = (7.43209e-06 -5.82378e-08 -3.71842e-07)
|Linear momentum| = 7.44162e-06
Linear kinetic energy = 2.72171e-05
model1:
- escape = 0, 0
- stick = 0, 0
- escape = 0, 0
- stick = 0, 0
- escape = 0, 0
- stick = 0, 0
- escape = 0, 0
- stick = 0, 0
- escape = 0, 0
- stick = 0, 0
- escape = 0, 0
- stick = 0, 0
PIMPLE: iteration 1
smoothSolver: Solving for U.airx, Initial residual = 0.704674, Final residual = 9.70184e-06, No Iterations 24
smoothSolver: Solving for U.airy, Initial residual = 0.772893, Final residual = 9.88161e-06, No Iterations 73
smoothSolver: Solving for U.airz, Initial residual = 0.971386, Final residual = 9.89935e-06, No Iterations 110
GAMG: Solving for p, Initial residual = 0.707649, Final residual = 0.00314431, No Iterations 3
time step continuity errors : sum local = 2.55388e-09, global = -2.52526e-12, cumulative = -6.46866e-09
GAMG: Solving for p, Initial residual = 0.564502, Final residual = 9.43709e-07, No Iterations 38
time step continuity errors : sum local = 0.000707365, global = 0.000593692, cumulative = 0.000593686
smoothSolver: Solving for epsilon.air, Initial residual = 1, Final residual = 0.337702, No Iterations 1000
bounding epsilon.air, min: -571.1 max: 2.71286e+26 average: 4.21011e+21
smoothSolver: Solving for k.air, Initial residual = 0.999799, Final residual = 0.914737, No Iterations 1000
mpirun has exited due to process rank 4 with PID 3677 on
node MSI exiting improperly. There are two reasons this could occur:
1. this process did not call "init" before exiting, but others in
the job did. This can cause a job to hang indefinitely while it waits
for all processes to call "init". By rule, if one process calls "init",
then ALL processes must call "init" prior to termination.
2. this process called "init", but exited without calling "finalize".
By rule, all processes that call "init" MUST call "finalize" prior to
exiting or it will be considered an "abnormal termination"
This may have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
Have you solved your problem? I met a similar problem as yours. When I run the case, the case divergence suddenly. The iteration for k and epsilon become 1000 suddenly.
Kind regards,
Ping
