Problem in running coarse mesh(on the other hand fine mesh is running) |
July 12, 2017, 04:19 |
Ashok
Rep Power: 9 |
Good Morning,
Recently I encountered a Problem. I have created 2 different cases with only difference in mesh(one is fine mesh and other is coarse), the rest of settings are undisturbed. Inspite of all the settings being same except mesh, coarse mesh case is not running but fine mesh case is running successfully. The tar files are attached below for both the cases. Someone please kindly help me to sort out were the Problem is. |
July 12, 2017, 04:32 |
Kevin van As
Rep Power: 20 |
Would you please specify a little more information?
What does "not running" mean? Does that mean the case crashes at the very first timestep, or that the case hits a FPE after some time, or ...? If such a crash does indeed happen, you should post the last ~3 timesteps of your log file. |
July 12, 2017, 04:35 |
You should also post checkMesh output for both meshes.
July 12, 2017, 05:00 |
Ashok
Rep Power: 9 |
Not running means, getting error like
--> FOAM FATAL ERROR: Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 1e-300 Specified mass inflow : 1.6802e-20 Specified mass outflow : 1.83295e-20 Adjustable mass outflow : 0 Once after running interFoam I gets error message as above only in case of coarse mesh but fine mesh case runs fine. |
July 12, 2017, 05:03 |
Ashok
Rep Power: 9 |
checkMesh- coarse Mesh case
Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 16151 faces: 46100 internal faces: 43900 cells: 15000 faces per cell: 6 boundary patches: 3 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 15000 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology bottomWall 500 521 ok (non-closed singly connected) atmosphere 500 521 ok (non-closed singly connected) movingWall 1200 1240 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.063 0 -0.063) (0.063 0.5 0.063) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (2.35058e-17 1.72541e-16 -3.47107e-18) OK. Max cell openness = 2.36956e-16 OK. Max aspect ratio = 11.8005 OK. Minimum face area = 1.07407e-05. Maximum face area = 0.000164764. Face area magnitudes OK. Min volume = 1.79012e-07. Max volume = 6.615e-07. Total volume = 0.00620888. Cell volumes OK. Mesh non-orthogonality Max: 31.7106 average: 6.63087 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.2423 OK. Coupled point location match (average 0) OK. Mesh OK. End CheckMesh- fineMesh Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 104091 faces: 304000 internal faces: 296000 cells: 100000 faces per cell: 6 boundary patches: 3 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 100000 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology bottomWall 2000 2041 ok (non-closed singly connected) atmosphere 2000 2041 ok (non-closed singly connected) movingWall 4000 4080 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.063 0 -0.063) (0.063 0.5 0.063) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (4.71457e-17 6.07412e-16 1.49041e-17) OK. Max cell openness = 2.41381e-16 OK. Max aspect ratio = 15.9624 OK. Minimum face area = 2.38208e-06. Maximum face area = 4.94674e-05. Face area magnitudes OK. Min volume = 2.38208e-08. Max volume = 9.9225e-08. Total volume = 0.00622808. Cell volumes OK. Mesh non-orthogonality Max: 37.9828 average: 7.25481 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.36114 OK. Coupled point location match (average 0) OK. Mesh OK. End In case of much more information, Im happy to share. Thank you |
July 13, 2017, 03:35 |
#6 | |
Ashok
Rep Power: 9 |
July 13, 2017, 03:36 |
Ashok
Rep Power: 9 |
July 17, 2017, 04:56 |
Ashok
Rep Power: 9 |
Hello, am still waiting for the Reply. Any sort of help is appreciated. Thanks in advance
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
