-   OpenFOAM (https://www.cfd-online.com/Forums/openfoam/)
-   -   Missing library (https://www.cfd-online.com/Forums/openfoam/191221-missing-library.html)
vcvedant August 3, 2017 17:53
Missing library
I was trying to implement a user defined turbulence model but I think I accidentally removed libincompressibleRASModels.so. I am using OpenFOAM-2.3.x
For the user defined model, in the /Make/files, I wrote
mykEpsilon.C
LIB = $(FOAM_LIBBIN)/libincompressibleRASModels
and then ran wmake.
Now when for a case I previously used, I tried kEpsilon model using simpleFoam and got the following error:
simpleFoam: error while loading shared libraries: libincompressibleRASModels.so: cannot open shared object file: No such file or directory
Please help me fix this problem
vcvedant August 3, 2017 18:19
Problem fixed
I fixed the problem. As mentioned I had deleted the library while making a new model.
I went to /turbulenceModel/RAS directory and ran
wmake
Then re-ran my case.
