patch mass flows in 1706
Hello all,
I am evaluating 1706 compared to previous versions, and one very large annoyance is the persistent difficulty in getting proper mass flows. In the case of faceZone mass flow rates, I can use the fluxSummary function object, but this STILL lacks the "phi flip" functionality of swak4foam and thus gives rubbish values, since faceZones are not oriented. For patches however, I can't get a flow rate at all. The "flowRatePatch" function from the OpenFOAM.org release is non existent, and fluxSummary works for surfaces, faceZones, and cellZones. Source: http://www.openfoam.com/documentatio...y.html#details Does anyone know, if there a way to get patch mass flows in 1706? |
Hi there,
Why not just use swak4Foam? I personally find the swak4Foam interface to be much more consistent across multiple OpenFOAM versions anyway. Regards, Philippose |
I will try that as well, haven't tested if it work with 1706. But in general I would like to use the standard distro as much as possible. There have been mass flow calculators in the past, so there's gotta be one in this 1706.
You seem to already know how to sample on a faceZone. You can create a faceZone from you patch via topoSet. Or you directly use a faceSource functionObject:
https://github.com/OpenFOAM/OpenFOAM...e/faceSource.H |
Right. 1706 has surfaceFieldValue.
surfaceFieldValue1 |
So that's where it went! Brilliant, thanks a lot :-)
Which versions did you compare to? AFAIK that's how it's always been and newer CFD-direct versions work differently (since introducing the postProcess tool).
