partial slip to moving wall
Old   August 29, 2017, 07:17
Default partial slip to moving wall
Ashok
ashokmoravaneni is on a distinguished road
Hello everyone,
can any one tell me how to apply partial slip BC to a wall moving with velocity(say for ex.-0.6679 vertically down). I have defined BC of moving wall like below in U field.
in U field:
movingWall
type partialSlip;
value uniform (0 -0.6679 0);
valueFraction uniform 0.5;
in P field:
movingWall
type zeroGradient;
If I define velocity as mentioned in U field above, the wall doesnt take any velocity. Only if fixed value is assigned like this, wall is moving.
movingWall
type fixedValue;
Any kind of help is appreciated. Thanks in advance.
ashokmoravaneni is offline   Reply With Quote
Old   August 30, 2017, 16:26
Yousef
ykanani is on a distinguished road
For many boundary conditions, the "value" entry specified in the boundary condition is just an initial value and I believe this is the case for the partial slip as well.
This is not the case for the fixedValue where OpenFOAM imposes the value according the the "value" entry in the boundary condition throughout the simulation.
I think this explains your observation. I don't know how you can apply partial slip on a moving wall though.
Regards,
ykanani is offline   Reply With Quote
Old   August 30, 2017, 16:57
Ashok
Regards,
Thank you for your Respose. I still couldn't find out how to implement partial slip to a moving wall. One can apply partial slip to a fixed wall in which fluid flows.
But in my case it is reverse. Fluid is filled in a cylindrical tube closed an bottom and side walls are moved with some velocity. So I wanted to give velocity and partial slip at the same time to my wall.
Old   March 3, 2018, 12:55
vishal
vishal_s is on a distinguished road
Hello Ashok,
I am also trying the same thing. Did you figure out how to implement it?
vishal_s is offline   Reply With Quote
Old   March 8, 2018, 10:37
Saideep
Saideep is on a distinguished road
May be I am completely wrong but I am trying to understand how this can be done.
Partial Slip:
means the wall is stationary but the wall cell faces can have a non-zero velocity.
Impact: reduces/ relaxes large magnitudes of viscous forces/ stresses on the boundary cells.
Is the analogy not same considering a moving wall with a no-slip boundary condition? That is (please correct me if wrong), there are only two possibilities but not sure what happens. Either the parabolic flow profile is violated, else as above the viscous forces reduce in magnitude.
I somehow get a feeling that movingWall with slip can be dealt by just using slip/ partial slip.
Saideep is offline   Reply With Quote
Free slip moving wall BC Claudio OpenFOAM Running, Solving & CFD 35 December 1, 2021 22:37
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
