Can we use Open Foam to make apps for commercial purposes?
Like Tree1Likes
  • 1 Post By piu58
Old   September 14, 2017, 18:48
Default Can we use Open Foam to make apps for commercial purposes?
ferferimori is on a distinguished road
I appreciate if experienced users can provide me with following information:
I need to develop a code with specific application for a company. The company does not care how I do it, but I must supply them with a an underlying code that produces correct results as well as a GUI to interact with.
The second part is not a problem. But the first part can be quite time consuming if I code everything from scratch. Is it possible to use Open Foam as the underlying engine, or Open Foam needs special license for commercial usage?
Thanks
ferferimori is offline   Reply With Quote
Old   September 15, 2017, 00:36
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
Openfoam is under the GPL licence. You may use it for commercial application. If you write some code form scratch you may sell it. But you have to give your customer the right sharing the remaining code / programs freely.
If you modify existing code you have to let the result under GPL licence. As far as I understand you are not allowed to sell this piece of code. You may bill for the adaption work of course, but don't check any licence fees.
ferferimori likes this.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
commercial licence, open foam; freelancer
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 02:36
