periodic (cyclic) boundary - fluent3DMeshToFoam
My computational domain has a shape of slice of a cylinder. I have generated my mesh on this domain using ICEM. Two sides are defined as periodic boundaries. However, when I use fluent3DMeshToFoam to convert the mesh in OpenFOAM, the software faces issues due to the periodic (cyclic) boundary. A suggested alternative way is to define these periodic boundaries, lets say as symmetry boundaries, then convert the mesh using fluent3DmeshToFoam. Then you use createPatch funtion ( via createPatchDict file) to convert your symmetry boundaries to cyclic boundaries. I performed these steps. I modified createPatchDict file as suggested. When I run createPatch, at the beginning, it works fine but I get the following error at the end. > FOAM FATAL ERROR: For patch SIDE11 there are 159185 face centres, for the neighbour patch SIDE22 there are 160271 From function void Foam::cyclicPolyPatch::calcTransforms(const primitivePatch&, const pointField&, const vectorField&, const pointField&, const vectorField&) in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 156. FOAM exiting Obviously, the number of face centres are different on each side. Is there any way to solve this problem? I would appreciate any suggestion Cheers |
maybe there is something wrong with your createPatchDict
