.eMesh with foam-extend. surfaceFeatureExtract does not work.
Old   October 12, 2017, 10:54
Default .eMesh with foam-extend. surfaceFeatureExtract does not work.
Katt
Katt is on a distinguished road
Hi guys;
Out of intense curiosity, how to generate motorBike.eMesh in foam-Extend 1.6/ 3.2.
I could generate the .eMesh using normal openFoam version (3.x) using "surfaceFeatureExtract" that reads from system/surfaceFeatureExtractDict.
Somehow, the .eMesh generated in foam-extend is seen to be inconsistent with what snappyHexMesh can work with.
I used the following command:
surfaceFeatureExtract -includedAngle 150 constant/triSurface/motorBike.stl constant/triSurface/motorBike.eMesh
After struggling for quite long, I do realize the working structure of surfaceFeatureExtract has changed between OF2.2-2.3 versions whereas at-least exporting the mesh from OF3.x to FE1.6 doesnt work (complaints about errors in reading faces file and so on).
Thanks;
KT
Katt is offline   Reply With Quote
Old   October 17, 2017, 07:08
Default solution.
Katt
Just an update for what happened to me,
I am not yet sure what really does "surfaceFeatureExtract" do in foam-extend 1.6/3.2.
In parallel, I do always have a relatively latest release of OpenFOAM (3.x), where the surfaceFeatureExtract works with the "surfaceFeatureExtractDict" file placed in the system.
First try: Everything in OF3.x works, but the file structure between OF3.x and FE1.6/3.2 are different. So, after matching the files and a few keywords, I tried seeing the output mesh from FE1.6/3.2 but I got a few binary format errors/ complaints.
Second try: OF3.x writes the "faces" output of blockMesh in a binary format (I guess it is default). So, I wanted to see what explicitly is going wrong. So, transformed the binary output to ascii by changing the "system/controlDict/writeOutput" to ascii.
Then I run, surfaceFeatureExtract-> blockMesh -> snappyHexMesh -overwrite and export the mesh to FE1.6 by managing and ordering the files as required to be read by FE1.6 and it finally works.
I guess, the way is to mesh in latest versions of OF and export the meshed domain to FE (older versions).
foam extend 1.6, snapphexmesh, surfacefeatureextract
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." lethu OpenFOAM Meshing & Mesh Conversion 1 June 3, 2020 07:49
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 02:21
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
